Author Topic: money pit strikes again...  (Read 1043 times)
bmcafee
« on: July 22, 2011, 05:02:43 PM »
 ??? Was driveing home this morning and rounding a corner the scooter just died. no juice getting to motor turn signals or horn, fuses are intact. So frustrating, I think I will have to order a new wiring harness...
slugrocket rob
Re: money pit strikes again...
« Reply #1 on: July 22, 2011, 05:30:28 PM »
Wow... I thought the term "money pit" was reserved for my vintage scooter  :).
JENNY
« Reply #2 on: July 22, 2011, 07:36:47 PM »
BEFORE YOU REPLACE THE WIRING HARNESS YOU MAY WANT TO CHECK IGNITION SWITCH, BATTERY, STATOR N VOLTAGE REG/RECT?
bmcafee
« Reply #3 on: July 22, 2011, 10:34:41 PM »
the battery is good so I will check the ignition but beside that I dont really want to go through a mile of wire with a vot meter to find a short
« Reply #4 on: July 23, 2011, 11:37:56 AM »
starte it up then unplug the stator and check to see if you are geting power there.if so you are good and it must be the voltage reg.
bmcafee
« Reply #5 on: July 24, 2011, 07:17:45 AM »
I cant start it.. there is a shrt some where. hince "no electricity getting anywhere" battery and fuses are good but there is  problem somewhere in the harness. ot it is an ignition issue. too hot to work in the garage the last couple days heat index over 110, with hella humidity.
