Author Topic: Dr Pulley 20x12 14GR  (Read 73573 times)
kfc.android
Re: Dr Pulley 20x12 14GR
« Reply #240 on: July 15, 2014, 02:55:31 PM »
In this case do NOT apply oil. Reason is the Var, and clutch nuts are a specialty item. They are capture nuts meant for one time use. They are kind of squished oblong from the factory, and will gall the threads if installed dry.
You will be re-using them so the locking they do has been undone. Lok-Tite is really what you need. Blue, and not red.
Thanks again, Zombie. Really don't know what to do without you :)
« Reply #241 on: July 15, 2014, 06:01:33 PM »
It's all good for sure.
I have a friend that really cares about people, and he also knows how to make a buck (or six).
He has asked me a hundred times to join his "Lifestyle Design" site. The idea is anything you need you go there, and for a nominal fee someone there will help you accomplish almost anything.
It just wouldn't feel right for me, but it is tempting...
The site is not built yet so I have time... Maybe a 50/50 split of proceeds to some revolving charities type deal would ease the burden.
Thinking out loud, again
kfc.android
« Reply #242 on: July 18, 2014, 04:44:07 AM »
Ok, it's time for me to update and ask :)
I got the 15.5g Dr. Pulley slider a while ago, but I have heard a transmission "tune-up" would restore some power and reduce rattling/shaking
So, in order to have a fair comparison between Dr. Pulley sliders and stock rollers, I decided to perform a tune-up today.
The so called "Tune-up" is very simple, just clean up the inner part of clutch (movable drive) face with some brake cleaner
and most important, to re-surface the glazed clutch shoe with sand paper to have better and smoother grip
The whole process is about 1 and 1/2 hour or so, not very difficult, I strongly recommend everyone to do this tune-up if you have appropriate tools.
Now the bike feels faster from 0 - 70 mph, the low rpm rattling/shaking is gone (or minimal) even at 3~4k rpm, and somehow quieter.
One question,
After I took out the drive face assembly out, seems like there's four holder keeping the ramp from moving and I just couldn't take the ramp plate apart  :(
https://www.dropbox.com/sh/d0nxzy2i99ut1or/AAB_5nTrLbqaB9V7KfBg8CNAa/Transmission%20Service/2014-07-17%2020.02.23.jpg
Any idea or suggestions?
I also upload all related photo to my dropbox, here's the link:
https://www.dropbox.com/sh/d0nxzy2i99ut1or/AAAth52Mx2FJrzNgbY3_HUFea/Transmission%20Service
Will update after I put on those Dr. Pullry sliders :)
« Last Edit: July 18, 2014, 04:52:30 AM by kfc.android »
« Reply #243 on: July 18, 2014, 05:15:28 PM »
I'm not sure I understand the problem. What I do is install the drive boss into the front of tha Var, and use that to push out the ramp plate. They can be stiff but in reality they should just fall out.
Two things to look for here as well. The drive boss should spin free on the crank shaft w/ NO wobble or side clearance, and the same goes for the fit inside the var. There should be no wobble or side clearance.
If there is you have to replace the boss, and the var.
After you get the ramp out try turning it to a new alignment to get a free movement. If it still jams up you may have bent the aluminum guides from use. Again the var may need replacement or at least a bit of polishing up on those guides to give free movement.
I hope some of this helps...
kfc.android
« Reply #244 on: July 24, 2014, 03:55:36 PM »
So, I finally got a time to put on those 15.5g sliders.
Thanks Zombie, I used the way you mentioned, and it comes out easily.
I also checked as you mentioned, so far no wobble and side clearance :)
My detailed report can be find in another thread (post#38)
http://www.kymcoforum.com/index.php?topic=5581.38
Cvitalo
  • Kymco Downtown 300i
« Reply #245 on: June 29, 2016, 08:43:56 AM »
Hello! I am a new member of this forum and new owner of Downtown 300i.
Everyone here are speaking about Dr. Pulley sliding rollers, but you are all calling them sliders even sliders, as I understand,  are that 4 plastic pieces that are adviced to be installed with 8 Dr. Pulley sliding rollers.
My question is about this plastic sliders. I want to change them as well, but do I really need to put Dr. Pulley's sliders? Problem is that this four plastic pieces of Dr. Pulley are 22 euros, and I believe the price for genuine Kymco is much lower. Or, am I wrong? Will I lose something if I put or leave "ordinary" sliders?
Cpi Popcorn 50, Aprilia Sportcitiy 200i, Aprilia Scarabeo 250i, Aprilia Scarabeo 200i, Yamaha Majesty 400, Kymco Downtown 300i
TANWare
« Reply #246 on: June 29, 2016, 05:11:26 PM »
You will need the 8 sliders. I prefer the 14gr as then you will gain 500 or so RPM under power take off. Once cruising at highway speeds the actual RPM is lowered over the stock rollers. With the 15GR you still will get slight increase in RPM under power and a much lower RPM at speed.
The 14GR seems to keep the best possible power band available at all times. Now these will never be a hot rod, nor a wheel stander, but I can attest the bike is much better ride with the sliders. it is much easier to also out accelerate local traffic as well. I have even found it better at rolling acceleration for those times you need to pass local traffic too.
at 12MPH I find the clutch disengages and allows the bike to roll without the engine slowing it down. I am always conscious of this as I watch to be sure it coasts unencumbered without an drag. The more freely it coasts without having drag the better the MPG and general performance of the bike. The biggest improvement I noticed with this is switching the gear oil to Royal Purple synthetic oil in the FD.
Cvitalo
« Reply #247 on: June 30, 2016, 08:28:47 AM »
I was actually speaking about this:
http://drpulley.shopnix.de/product_info.php?products_id=33
But, as I asked my local dealer, people don't usually change this plastic sliders. Obviously they last very long. So I won't bother.
I have another question, but I will open a new topic for this, because I need answer soon.
« Last Edit: June 30, 2016, 11:04:52 AM by Cvitalo »
MJR
« Reply #248 on: July 06, 2016, 05:49:34 PM »
From what I've read those are suppose to fit better than the OE ones reducing slop and noise
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
TANWare
« Reply #249 on: July 07, 2016, 12:57:48 AM »
I never changed mine out. When I put in the sliders I left the stock ones in.
tvniklas
  • Passed the golden age 40...
« Reply #250 on: October 01, 2016, 06:11:57 AM »
Hello
I want to try 15g DrPulley Weights but unsure about the size.
Is it 20x12 for mine to?
I have a DT 300i made in January 13
« Last Edit: October 01, 2016, 06:14:31 AM by tvniklas »
Kymco Downtown 300i ABS -2013
ODO: 9950km
Dr Pulley 15g / Orginal rollers  (change all the time)
Gas average 0,29L/10km
Kymco Like 125  -2016  -Sold
Kymco Agility 50 -2015 -Sold
I have 14g ,15g and 15,5 Pulley´s to sell
kneeslider
« Reply #251 on: October 01, 2016, 07:46:50 AM »
My DT is a 200. Would the weights be the same for mine as with the 300's?
2019 Yamaha X-Max 250
« Reply #252 on: October 01, 2016, 10:21:44 AM »
Hello
  2011 downtown 85,000 Km.  20/12 15 gram sliders are the right ones ,. for all around touring rides,.  14 gram for jockeys for faster take off,s    de dee
Cvitalo
« Reply #253 on: October 01, 2016, 11:00:14 AM »
I sent a question to dr.pulley in germany and got the answer the next day.
tvniklas
« Reply #254 on: October 01, 2016, 02:27:24 PM »
Thank you de dee
15g it is!
ODO: 9950km
