Author Topic: Agility cuts out?  (Read 885 times)
KYMCO-LOCK
Agility cuts out?
« on: July 23, 2011, 12:15:13 AM »
How do everyone.
Bought my Agility 50 '09 about 2 weeks ago, second hand.
The problem I am having with it is, it cuts out when I come to a stop.....
If i put the key in and start it up and let it tick over for 4-5 minutes then drive off, it isn't as bad, it may cut out, it may not, but If I turn it on and let it tick over for a minute or 2 then it will cut out when I stop. It stops cutting out after I have been driving for 10 mins or so. What seems to be the problem are am I doing something or not doing something?  p.s  It has about 5300km on the clock and has had it's CDI cut.
Cheers.
« Last Edit: July 23, 2011, 12:17:28 AM by KYMCO-LOCK »
Re: Agility cuts out?
« Reply #1 on: July 23, 2011, 11:33:32 AM »
tick over what do you mean by that.
streido
« Reply #2 on: July 23, 2011, 03:56:56 PM »
You maybe just need to turn up your idle screw a little bit if its the revs dying away then it cuts out.
Chaos is my co-pilot.
