Just went for my first ride on my agility with the BBK installed, so much power!! Didn't open it up all the way but gave it a little gas to help the rings get some pressure and seat correctly for break in.
I will list my setup below, but here's my issue:
It is definitely idling a bit high, especially when I sit down. I know the higher idle when I'm seated is because the way the foam filter is positioned it gets just a little bit smushed by the fender which I plan on correcting with a hose soon. But when at idle without me seated it is still idling a little bit high. I'm thinking its getting too much air but not sure to be honest. I only have the idle screw turned out 1 or 1 1/2 times. I'm not sure if I should turn it in any more? Will turning it in too far cause any damage because of lack of fuel? Should I try a bigger jet?
Thanks
