Author Topic: Think I may have broken her :(  (Read 1535 times)
hungryrussian
  • Kymco Agility 50 "Sonic"
« on: July 27, 2011, 02:28:21 AM »
It's been a while guys hope you are all doing well, i seem to be in need of your assistance again... It was 121 degrees on the heat index today and i was scootin along when all of a sudden i lost a good amount of power then the scoot died on me, it overheated of course the plug was pretty burnt and smoke was coming out of the crankcase ventilation tube (tube that comes off the valve cover) It burnt quite a bit of oil in this process so when i got it home (in the back of a truck of course) i changed the oil and made sure the carb and transmission were in good working order then i test started it. it ran fine except for it taking a little extra gas to get it to start but has developed a tick at idle that sounds to me like it's coming from the head. i'm on my way outside to pull the head and check for bent valves, excess carbon, scars on cylinder wall, ect just wondering if anyone had any other ideas of things i should check after an overheating. i think i may have scarred the cylinder considering i drained about a cup of oil out of the bike which is way less than what was in there when i left this morning but i guess we'll see  :-\
'08 Agility 50, 72cc BBK, Naraku HS High Speed Variator, some clutch tweaking, UNI filter with homemade cold air setup, Leo Vince Handmade Titan exhaust, lots of random upgrades i'll never be able to remember.. the look on people's faces when i put a knee down through a curve makes it all worthwhile
hungryrussian
Re: Think I may have broken her :(
« Reply #1 on: July 27, 2011, 03:57:00 AM »
well she's running nice & smooth again i cleaned the valves and re-installed didn't see anything traumatic in there, let it idle for about 15 minutes then changed the oil again then test rode. still getting that tapping sound kinda sounds like an exhaust leak but it makes something like a high pitched buzzing noise while riding ... i called it a night but any ideas would be appreciated i'll be digging back in tomorrow
streido
« Reply #2 on: July 28, 2011, 12:19:00 AM »
Try checking the small chrome pipe that sit in front of the valve cover, under the seat. My had a small hole in it and gave a ticking sound. I thought I had a tiny hole in my exhaust but eventually found that. If you put your ear down near the vent under the front of the seat you would hear it coming from behind there without removing any panels, if it is that.
Chaos is my co-pilot.
« Reply #3 on: July 28, 2011, 12:46:54 PM »
im thinking valve adjustment.
hungryrussian
« Reply #4 on: July 28, 2011, 09:48:56 PM »
i got the feeler guage from work as mine doesn't go down far enough & i'm about to go adjust them it ran amazing for me today faster than ever actually but it still has what i have detemined to definitely be an exhaust leak... going to find it now :)
hungryrussian
« Reply #5 on: August 01, 2011, 03:10:34 AM »
well i adjusted the valves the other day intake was a tad tight & exhaust a hair loose they're both back at .04 & she's running fast but my exhaust has quieted very noticeably and i can still hear the exhaust leak i checked everything over twice can't find anything at all so until i can figure out how to find it i'm ridin she's runnin too fast not to ;D
streido
« Reply #6 on: August 01, 2011, 02:03:17 PM »
Did you check the U shaped chrome pipe in front of the valve cover? Think its called the Exhaust Gas Recirculation tube. Mine had a small hole on the bottom I couldnt see, sounded like a small exhaust leak.
whiteknight
  • ..Knight Tweed..
« Reply #7 on: August 14, 2011, 09:13:51 PM »
i dont know if i have the same problem but everytime i deccelerate theres this fluttering noise almost like a turbo wastegate. hasnt caused any probs (so far)  didnt know if this might also be a zaust leak. she has been bogging down recently aswell and recently died when i stopped for traffic and took 15 mins to start again, hasnt done it since but it did worry me a little.
