Author Topic: Can someone help me dial in carb settings?  (Read 1091 times)
biederboat
« on: July 28, 2011, 01:26:20 AM »
I went from a "no power" situation to hesitation while accelerating.  I cleaned out the jets, that seemed to get it basically running.  Now, if you dump the throttle quickly, it will almost die.  There's virtually no power for a few seconds.  If you ramp up more slowly, it will do better but still hesitate.  Once you're up to full throttle it's fine.  Also, the idle is a bit rough.  I finally figured out there's an "air screw" and a "throttle stop screw" but I'm not real clear (even after searching) what exactly the function of both of these air and how they should be adjusted.  I'm assuming the air screw is the mixture screw and that's the one that should be out 2.5 (to start with anyway)?  I can't find anything on I would normally assume would be the idle speed screw (the throttle stop screw).  It doesn't seem to function like one and I can located the nominal adjustment.  What does this screw do and how should it be adjusted (where do I start)?
I (and the wife!) would greatly appreciate any advice.
Thanks,
BB
biederboat
Re: Can someone help me dial in carb settings?
« Reply #1 on: July 29, 2011, 02:50:24 AM »
Anyone???   :)
GM6969
« Reply #2 on: July 29, 2011, 01:24:01 PM »
Hi,
maybe some help from videos:
In German, but you will hear the perfect sound of the engine:
As some of riders recommend airscrew to be 1 1/2 and the others say best is 2 1/2... currently in my scoot its very different...
Airscrew is out only 0,25 from one turn so its less than 1/2.
Drive on the scooter just about 2-3km, and look sparkplug, the color of it should be like a coffe. If its not then you need to play with those 2 screws, rew. and air.
Good luck.
« Last Edit: July 29, 2011, 01:29:17 PM by GM6969 »
