Author Topic: grand vista 250  (Read 1891 times)
dacjordan
grand vista 250
« on: July 29, 2011, 10:30:49 AM »
running hot  coolant level fine  what could cause that?
can hear fan running  also losing power uphill
« Last Edit: August 20, 2011, 11:35:54 PM by dacjordan »
MaryK
Re: grand vista 250
« Reply #1 on: July 29, 2011, 12:18:07 PM »
Does the fan run ?
If not: bad fuse, sensor or fan motor.
scoot safely,
New Rider in 2010
2009 GrandVista 250
Hoolander2
Re: grand vista 250
« Reply #2 on: July 29, 2011, 03:47:40 PM »
Like MaryK says, check to see if the fan runs.  Air trapped in the cooling system would cause that too.
dacjordan
Re: grand vista 250
« Reply #3 on: August 20, 2011, 11:36:59 PM »
can hear fan running   losing power going up hill  how would i know if air trapped?
MaryK
Re: grand vista 250
« Reply #4 on: August 21, 2011, 02:20:36 PM »
Some moore questions:
Is the scooter new ?
Has it run hot since you got it ?
have you made any changes recently before it started to run hot ?
Are you riding in stop & go traffic or on the move when it gets hot?
To check for air in the cooling system, you have to open up the radiator cap (when cold) and see if the coolant level is at the "top" (where the caps seals) of the radiator.  If not, then add 50% Prestone or get motorcycle/scooter coolant.
Also make sure that the overflow bottle is at the correct level of coolant.
A lot of stopped idling in 105° weather may be the problem and the only cure is to plan a different route or time to ride.
New Rider in 2010
2009 GrandVista 250
JustWantToRide
Re: grand vista 250
« Reply #5 on: August 22, 2011, 03:06:03 PM »
Are you getting coolant into the catch tank when it is warmed up?  If not - then you don't have enough coolant in it or it isn't pumping it.  You basically have 2 thermostats on that engine.  One is on the back of the radiator under the main hose - and it controls the fan.  That one seems ok.  The other - is the thermosensor down on the pump - and it needs to open to allow the coolant to flow.  If you aren't getting coolant into your catch tank when it's hot and you've got enough coolant - then I would suspect the thermosensor.
2009 Xciting 500Ri
   52mpg so far
