If you have rear disk brakes, there will be another reservoir by the left side brake lever.
Be sure to use brake fluid from a newly opend bottle.
Brake fluid picks up moisture from the air. The moisture
makes the fluid boil at a lower temperature and also
makes the solution more corrosive to the metal brake parts.
Scoot Safely,.
