Author Topic: Valves  (Read 870 times)
P250Fanatic
Valves
« on: August 05, 2011, 12:13:16 PM »
Are you guys super strict about adjusting the valves every 4000 km? I've been extending this interval a bit...:-\
Re: Valves
« Reply #1 on: August 05, 2011, 01:59:32 PM »
Checked the valves on my S8 at 4000km.  They where all within spec.  I'll probably do it every 4000km until the warrantee expires then I'll extend it especially if the clearances don't change much.  If you're valve clearances change every 4000kn, then that's a good interval, if not then extend it.
Agent Bob
Re: Valves
« Reply #2 on: August 10, 2011, 11:33:02 PM »
It seems on the face of it that using synthetic motor oil would increase the interval, since synthetic reduces friction,  and therefore wear.
JustWantToRide
Re: Valves
« Reply #3 on: August 10, 2011, 11:43:29 PM »
Except the valves don' get adjusted for wear.  You still get the same back an forth motions and vibrations acting on the valves and their adjusters when you use synthetic oil - so I wouldn't use that as a reason to stretch it out.
2009 Xciting 500Ri
   52mpg so far
