Author Topic: Used GV should I drain and put new coolant?  (Read 2673 times)
bunker buster
« on: August 08, 2011, 10:04:19 PM »
Hello guys,
Should I drain the coolant and replace with a new one just like engine oil? Or it doesn't matter much?
What local brand of coolant do you guys use that I can get at pepboys, autozone or etc?
MaryK
Re: Used GV should I drain and put new coolant?
« Reply #1 on: August 08, 2011, 11:47:57 PM »
The manuals say to replace annually, but I doubt that any owner does it that often.  Most motorcycle companies say replace every 2 years.
Modern coolants are made to last 5 years.
We use Prestone premixed 50:50 which has a "No silicates" label on it.
We plan to change the coolant next spring using the Prestone and then wait 5 yrs before the next change.
If your cooland really looks bad when you drain it, you may want to change it annually until it looks good.
NOTE:  We have not changed the coolant in our GV 250 yet, so the information above is tentative.
Scoot Safely,
New Rider in 2010
2009 GrandVista 250
JustWantToRide
« Reply #2 on: August 08, 2011, 11:51:48 PM »
I'd second the Prestone at 50:50, and I would definitely change it.  You never know what someone else put into their radiator or cankcase...
« Last Edit: August 09, 2011, 07:20:41 PM by JustWantToRide »
2009 Xciting 500Ri
   52mpg so far
bunker buster
JustWantToRide
« Reply #4 on: August 09, 2011, 07:35:57 PM »
That's one of many that will work.  I think only the Heavy Duty and flush ones have silicates (fine sand) now.  It used to say "no silicates, good for all engines including aluminum".  I see the mention of all engines is still on the bottle.  They also have an Xtreme now which is specifically formulated for motorcycles.
2009 Xciting 500Ri
   52mpg so far
bunker buster
« Reply #5 on: August 09, 2011, 08:01:49 PM »
Thanks!
MaryK
« Reply #6 on: August 10, 2011, 01:26:28 AM »
I see that Prestone has changed labels since I bought my last gallon.  And they have a "new" product out
Prestone® Xtreme Sport™ Prediluted Motorcycle Coolant http://www.prestone.com/enca/node/423
So, we'llprobably buy this product the next time we change coolant in a scooter or motorcycle.
Scoot safely,
New Rider in 2010
2009 GrandVista 250
bunker buster
« Reply #7 on: August 10, 2011, 05:24:21 PM »
Boy Mary those are hard to find. Can't find it locally here at pepboys and autozone. Thanks anyway for the heads up!
MaryK
« Reply #8 on: August 10, 2011, 10:44:35 PM »
Yea, I haven't looked for it here, but I hope I can get the loacl parts store to order some.  I think it is fairly new.
Advance Auto carries more motorcycle stuff than the other stores here.
Lotaluck.  Probably we will have to use the Prestone premix or drop by the Honda dealer and buy Honda brand.
Scoot safely,
New Rider in 2010
2009 GrandVista 250
bunker buster
« Reply #9 on: August 15, 2011, 08:57:59 PM »
So I got me the prestone 50/50 and I Overfill the tank, how does one remove the excess coolant?
Will the liquid corrode/blemish the GV's plastic body? I know its mostly water but who knows?
JustWantToRide
« Reply #10 on: August 16, 2011, 03:04:52 PM »
The coolant won't hurt the finish if you rinse it off soon.
Did you fill it through the radiator cap?  If so - then you shouldn't have a problem.
If you filled the catch tank instead of the radiator then pull the hose from the radiator and hold it below the catch tank so it will siphon the fluid out (preferably into something).  Do it with a cold engine, then rinse everything off.
2009 Xciting 500Ri
   52mpg so far
bunker buster
« Reply #11 on: August 16, 2011, 10:42:28 PM »
Is the plastic tank near the ignition the catch tank?
