Author Topic: Tail light and flasher  (Read 1316 times)
asources
« on: August 09, 2011, 12:13:11 AM »
Hello Everyone ...
Ok i own a People S 50 4T 2009
I want to ad some led in my topcase ... but need to find the value of each color in the green cable under the tail ...
In that big Green cable there is 4 wires ...
Could someone help me with these colors ...
Stefan
marioG
Re: Tail light and flasher
« Reply #1 on: August 09, 2011, 04:51:12 AM »
cant understand - need pic....
u can use voltmeter, its pretty cheap!
need to be much more wires....
FUBAR is an acronym that commonly means "f***ed up beyond all recognition/any repair".
asources
« Reply #2 on: August 10, 2011, 06:44:28 PM »
Sorry there is 5 wires ...
Color goes like this :
Brown
Green/Yellow
Green
White
Orange
I need to know :
Witch one is left / right flasher
Tail light
Power ...
Thanks
fshfindr
« Reply #3 on: August 10, 2011, 07:23:53 PM »
Moderator, I was able to delete the unnecessary stuff, please do not delete.
Stefan; On the Dink 200i which I believe is the same scoot it is;
Green = ground
Orange to left signal
Brown to tail light
Blue to right signal
Green and yellow to brake light
No white on the diagram going into the rear lights.  On this diagram there is a plug there.  You can disconnect the plug to make testing easier with a voltmeter.  I hope that someone with more info posts.  I also need to know.
« Last Edit: August 10, 2011, 07:47:37 PM by fshfindr »
Richard L. in Bellmawr
fshfindr
« Reply #4 on: August 10, 2011, 07:29:29 PM »
UPDATE
PLEASE DO NOT DELETE THE PREVIOUS POST.  THIS ONE CAN BE DELETED IF YOU SO DESIRE.  I DID DELETE WHAT NEEDED TO BE DELETED.
Moderator, Sorry about the previous post, I don't know how to delete it.  I also don't know how to send a diagram or an attachment.
« Last Edit: August 10, 2011, 07:46:45 PM by fshfindr »
asources
« Reply #5 on: August 10, 2011, 10:06:34 PM »
Thank you ...
Will try this ... will try white in place of the blue ...
Where do you have this diagram ??
I have the service manual and it is not in there
Stefan
