Author Topic: idle is weird.. goes up when I sit on scooter???  (Read 1041 times)
streido
« on: August 14, 2011, 02:13:53 PM »
Anyone have any idea why my idle speed would be fine, 2000rpm, when on the centre stand, when I put it down off the stand its still fine, then when I sit on the seat it goes up to 3200rpm?
I dont weigh that much, 160lbs  ;D
Dont see any touching of the bottom of the seat compartment and the carb or anything obvious really so ideas welcome.
Going to go have another look now in case I missed something  :'(
Chaos is my co-pilot.
sidthesloth
  • Kymco ZX50
Re: idle is weird.. goes up when I sit on scooter???
« Reply #1 on: August 14, 2011, 02:17:09 PM »
This came up about a year ago, but I don't remember who it was or what the solution was.
streido
« Reply #2 on: August 14, 2011, 02:22:18 PM »
I'll have a search later on then sid if I cant figure it out, its very strange. Must be something pulling my accelerator cable somewhere I think.
Going to go look now before it rains.
Kenho21
« Reply #3 on: August 14, 2011, 04:06:52 PM »
Also check to make sure something in your intake system isn't getting compressed or compressing your throttle cable which could be loose at the same time.
streido
« Reply #4 on: August 14, 2011, 04:29:54 PM »
Fixed it  8) the throttle cable comes off the carb and thro a small tube to take it round the back of the engine, then round the other side it goes onto a clamp and away up to the throttle. The clamp was holding the cable too tight, when I sat on it it pulled it tighter. The clamp is bolted onto my cvt cover so I guess with all my f@%kin about with belts the last week I must have moved it and made it tighter. Anyway fixed now, just made some slack after the clamp, all good again.
Thanks for the ideas.
