Author Topic: Valve stem cap removal  (Read 1480 times)
alternatefox
« on: August 14, 2011, 05:53:40 PM »
Hello guys.  I am just wondering if there is a special tool to remove the valve stem caps from the tires?  Mine don't seem too twist off and the cap itself infers using a thick flat head screw driver?
So, should I go buy this thick flathead screwdriver? or is there another specialized tool for the job.
Thanks,
J
juice
Re: Valve stem cap removal
« Reply #1 on: August 14, 2011, 06:00:32 PM »
I would use whatever is needed including pliers and just replace the valve stem caps after if needed . Good luck .
JustWantToRide
« Reply #2 on: August 14, 2011, 08:07:17 PM »
I second the pliers...
2009 Xciting 500Ri
   52mpg so far
alternatefox
« Reply #3 on: August 16, 2011, 01:14:03 AM »
Thanks...  pliers it is
MaryK
« Reply #4 on: August 16, 2011, 05:18:50 PM »
Pliers to remove, then don't tighten the cap too much when installing, no pliers for install.
The design of the cap is to allow the removal of the valve stems using the "screwdriver slot" of the cap.
They are strange looking caps but I think they were trying to make rugged ones.
Scoot Safely,
New Rider in 2010
2009 GrandVista 250
alternatefox
« Reply #5 on: August 22, 2011, 02:02:49 PM »
Yep... pliers were the key.
Thanks guys.
