Hi,
hope to get some advice on a technical issue:
Agility 50 cc, 4 stroke. 2008 I belive. ~2500 km
Issue:
Scooter always worked fine, but stopped when I was waiting at red last week. Did start again, but didn't run long (10 sec) . Just died /faded away - sounds like ignition problems. Tried again a few hrs later and could drive home (2 min), however almost stopped a few times.
Spark plug has never been replaced (getting a new todday). However afraid it will not be enough.
Have done a few checks:
(1) Gas OK till after the filter (Flows when trying to start, seems like there is a pump "pushing sequently")
(2) Spark plug a little black, but not bad
(3) plug gets wet when trying to start (some gas reaches the cyl)
(4) no spark when running start engine (only after start engine doesnt run anymore, that is, I see 2-3 sparks after the start engine doesnt pull the engine (it still goes a few rounds around) So no spark until the start engine doesnt draw from the battery.
Hypotheses:
(A) spark plug worn out ?
(B) CDI / Coil not working properly?
(C) battery needs charging ? (had no problem running the start engine in the start, however got slower)
A and C to be checed today w new plug and recharged battery, any ideas how to check B? Any other advice?
Thanks in advance.
