Author Topic: (Almost) no spark / engine not runnign  (Read 9052 times)
sidthesloth
  • Kymco ZX50
re: belt too long?!?!!?
« Reply #15 on: August 18, 2011, 05:24:57 PM »
Should be easy to find one.
maglux
Re: (Almost) no spark / engine not runnign
« Reply #16 on: August 25, 2011, 08:58:34 AM »
Hmm, I'm still having problems..
Have tried with a new rectifier and different CDI - still no spark when start motor runs. With the other CDI, I hardly saw a spark at all. (With old CDI I see spark once after start motor has run)
Seems to me that the electrical setup is fine, have done pretty much all the checks I can think of (but not the start engine itself). Could it be something with the carburetor, chocke or something that also messes up the spark? The spark plug dont get soaked in gas, so might be some trouble in the carburetor - guess I'll have to work from that side now..
tips on what to look for is much appreciated. I have the Kymco manual
streido
« Reply #17 on: August 25, 2011, 10:44:23 AM »
Checked fuel filter isnt blocked up with gunk?
Chaos is my co-pilot.
maglux
« Reply #18 on: August 25, 2011, 02:31:00 PM »
yep, checked stream out of the filter, but not longer..
maglux
« Reply #19 on: August 26, 2011, 08:12:22 AM »
carb seems fine, however I have some questions to the auto bystarter. The manual specifies max 10 ohms between the terminals and my voltmeter reads 14 ohms - is this enough difference to mean anything?
maglux
« Reply #20 on: August 31, 2011, 01:37:37 PM »
How can i check that the cdi get the correct pulse from the pulser coil? Supposedly measure the voltage over the pulser coil ive been told, but what should the reading be?
maglux
« Reply #21 on: August 31, 2011, 06:00:06 PM »
And how can i check that there is actually gas going out of the carb? Gas ok till carb, pumped in, but as the spark seems dry i wonder if the gas is not flowing through
