Author Topic: removing the gas tank  (Read 3954 times)
thumpersnoopy
« on: August 21, 2011, 09:04:21 PM »
whats the best way to remove gas tank to get to the air filter?
badjoke
Re: removing the gas tank
« Reply #1 on: August 23, 2011, 03:32:26 AM »
Chainsaw or with a sledge hammer.
May have an issue getting it back on though.
JustWantToRide
« Reply #2 on: August 23, 2011, 05:30:15 AM »
Remove the right and left side covers and the right and left decorative covers under the fuel tank.
Remove the rear seat.
Remove the rear seat lock bolt and remove the front seat.
Remove the auto fuel valve.
Disconnect the fuel tube and remove the bolt on the end of the fuel tank.
Disconnect the fuel unit wire connector and fuel gauge wire.
Remove the fuel tank.
FUEL TANK INSTALLATION Install the fuel tank in the reverse order of removal.
Check that there is no fuel leakage.
Check the wire connectors for proper connection.
Werkstatthandbuch Kymco Quannon 125 Englisch
2009 Xciting 500Ri
   52mpg so far
quannon guy
« Reply #3 on: August 23, 2011, 01:42:51 PM »
Wana make a video of that and post it for us on youtube?? please :)
quannon guy
« Reply #4 on: August 23, 2011, 01:45:51 PM »
when you say auto fuel valve is that the same as the petcock? the metal nipple under the fuel tank?
JustWantToRide
« Reply #5 on: August 23, 2011, 02:20:41 PM »
Bring the bike to me in Austin and I'll remove the tank while you video.   ;)  The instructions are straight from the shop manual, which is why I put a link to it at the bottom of the post.
2009 Xciting 500Ri
   52mpg so far
badjoke
« Reply #6 on: August 23, 2011, 11:19:07 PM »
I'll make a video for you!  Just send me enough cash to get it started :)
thumpersnoopy
« Reply #7 on: August 24, 2011, 10:37:07 PM »
thanks all i just wanted to know so i can check my air filter
badjoke
« Reply #8 on: August 25, 2011, 01:14:44 AM »
Yeah... I should do that next round of maintenance too...
A friend of mine once took apart his car brakes without knowing what he was doing...so he took a photo everytime he took something off, went to the photolab to develop the film (remember that stuff??) and then did it in reverse according to photos.  Might be waaaay easier to do now with digital.
thumpersnoopy
« Reply #9 on: September 02, 2011, 06:39:26 PM »
man i havent seen a photolab in awhile
