Author Topic: Kymco people s 125 crankshaft.. Urgent help needed  (Read 1981 times)
kymcop125
« on: August 22, 2011, 11:07:26 PM »
Hi all,  :)
Currently I am disassembling my kymco 125 engine as it has a strange noise (found oil level low)  :( and thinking it might be the crankshaft bearing (shell).
Can the bearing be changed separately or I have to buy a complete new crank?
Where is the best place to buy parts cheap, I live in Malta Europe (near Sicily)
Thanks any help appreciated.  :D
Matt
sidthesloth
  • Kymco ZX50
Re: Kymco people s 125 crankshaft.. Urgent help needed
« Reply #1 on: August 23, 2011, 12:17:16 AM »
G'day kymcop125, this is not much help to you but, I don't think they used shell bearings on these engines, I believe they are roller bearings. You can get them rebuilt, but it is a specialist job, certainly not something I would try at home. I don't know about the 125 engines, but for the smaller 50cc engines you can find crankshafts from various aftermarket companies, I bought mine from an ebay seller who goes by the name autotech355, also uses Dr.pulley886 as another user name.
Have a look around, if you can find one it will be a lot cheaper than genuine.
kymcop125
« Reply #2 on: August 23, 2011, 12:21:14 AM »
Gd day,
Thanks, that's a good start at least :) .. will continue disassembly tomorrow morning
sidthesloth
  • Kymco ZX50
« Reply #3 on: August 23, 2011, 12:30:45 AM »
Are you sure the noise is from the crankshaft? It would be easier to check the top end first, and cheaper.
kymcop125
« Reply #4 on: August 23, 2011, 05:00:15 AM »
Probably , as I already checked the head and valve.
thanks
old mod
« Reply #5 on: August 23, 2011, 09:13:34 PM »
Hi kymcop, can you describe the noise? there are plenty of other reasons for rattles etc.
marioG
« Reply #6 on: August 24, 2011, 11:18:19 PM »
i got metal noise from exhaust at higher rpms....
rechecked my valves...there are good...but what about everything else?
secondary air filter?
FUBAR is an acronym that commonly means "f***ed up beyond all recognition/any repair".
