Author Topic: Help: Leaking coolant  (Read 1558 times)
bunker buster
« on: August 25, 2011, 12:06:33 PM »
Need help my GV is leaking coolant anything I can do before bringing to the shop?
Please checkout the photo
Close Up view
MaryK
Re: Help: Leaking coolant
« Reply #1 on: August 25, 2011, 02:12:26 PM »
You could try to tighten the bolts if it is leaking at the seal between the components.
BUT:   Use the correct wrench AND don't tighten too much.
The bolts should be metric and I'd use a box-end wrench or a 6-point socket.
I would keep my hand as close to the bolt as possible as I applied a moderate force.
OR Use a Torque wrench with a 6-point socket.
When it doubt, pay a professional
Scoot safely,
New Rider in 2010
2009 GrandVista 250
JustWantToRide
« Reply #2 on: August 25, 2011, 02:54:38 PM »
Are you sure it isn't leaking from somewhere else and just showing up there?  If it hasn't been messed with - then that seal is less likely to leak than the hose connections.  Check your hose connections and clamps before you touch the bolts.
2009 Xciting 500Ri
   52mpg so far
bunker buster
« Reply #3 on: August 25, 2011, 03:45:38 PM »
@Mary K
I have a torque wrench do you know what's the Nm or ft Lbs needed to tighten it?
@Just...
Yes that the only spot leaking.
Thanks
JustWantToRide
« Reply #4 on: August 25, 2011, 04:29:20 PM »
Per the service manual ---  Water pump cover bolt 7.8_ 11.8N-m
You can get a copy here on this forum:
http://www.scootforum.com/viewtopic.php?f=133&t=612&sid=31a98d5901a420e7e6bc7dfb144a8979
2009 Xciting 500Ri
   52mpg so far
MaryK
« Reply #5 on: August 25, 2011, 04:45:48 PM »
I cannot tell from your photo for sure.
There are 2 similar "covers" photos in the manual.
#1 is the water pump & it has 5 bolts in an uneven pattern.
Four of the bolts are for mounting.  Not sure of purpose of the 5th.  Probably for draining coolant.
It also has what looks like a hole in the top.
Then pic #2 is a side view which shows a weap hole in the side; referred to as "telltale hole"
Manual says" Inspect the telltale hole for coolant leakage.  If leaking, remove the right crankcase cover and replace the mechanical seal."
All of this is in section 12 of the manual and it tells how to replace the seal.
The 4 bolts hold the pump on with a gasket.
The torque for them is 7.8 to 11.8 Newton-Meter (Nm)
I think that the telltale hole may be the source of the leak... that is the mechanical shaft seal.
But you can do: #1  check the torque on the 4 bolts.
#2 is to remove the pump cover and replace the gasket.
And if not fixed, then it must be the shaft seal.
By the way... The manul recommends 30% glycol coolant instead of the usual 50%.
So if the leak  is minor, you may want to just add coolant until it gets much worse.
Scoot safely.
New Rider in 2010
2009 GrandVista 250
bunker buster
« Reply #6 on: August 25, 2011, 07:58:38 PM »
Super thanks Mary. Will try your suggestion. ;D
Treynor1
« Reply #7 on: August 26, 2011, 02:12:52 AM »
I will bet that is just a loose drain plug.  The gasket should not leak unless it was just replaced and crimped.
