Hi,
I've been finding that every time it rains hard, my scooter has big problems starting and running. The first time, I took it to a shop which found out that it was a problem with my CDI--probably got shorted from accumulated water. Mechanic replaced that and everything was ok... until the next time it rained. I looked at the connectors to the CDI and see that there are clear signs of water. Took the CDI out, cleaned the connectors, plugged it back in, and all was good. I had previously drilled some holes into the floor to help drain water but it doesn't seem to be enough. Anyone have similar issues with this? I'm debating whether or not I should drill more holes or try to seal off the CDI compartment.
-jeff
