Author Topic: How to Change Your Belt! :D  (Read 25880 times)
vespa50sp
Re: How to Change Your Belt! :D
« Reply #15 on: April 15, 2013, 02:58:21 AM »
Nice write-up. I'm about to install Dr Pulley sliders and a new drive belt on my People s250. I picked up a Harbor Freight electric impact wrench for $40 after their standard 20% off coupon on one item. I was surprised at how cheap the Kymco belt was, $60 with tax, and it has a pretty good rep also.
« Reply #16 on: April 15, 2013, 08:29:59 AM »
Thanks for sharing! Great one!  ;)
ScooterCommuter
« Reply #17 on: April 30, 2013, 07:37:09 AM »
The other thing I'd rec here (for all similar scoots) is, while you have the cover off, clean and lube the kickstarter, particularly the secondary gear. belt dust tends to accumulate there, binding the secondary gear to its retainer spring and the kickstart lever shaft tends to corrode and bind up if you dont use it often. You dont want to be caught with a dying battery away from home and a scoot that you can't kick over...
« Reply #18 on: April 30, 2013, 08:04:29 AM »
If my battery is low and can't turn the engine...I cannot anymore use my kick start... because I have a DC CDI.... won't work without a good battery....  I wonder what my kick start is for?  :(   With an AC-CDI, you can kick start if the battery is low or even dead...
ScooterCommuter
Re: Re: How to Change Your Belt! :D
« Reply #19 on: April 30, 2013, 07:16:50 PM »
You've still got enough juice to generate a spark when the battery is too low to crank it. Only just enough,  but without the extra load of having to turn the engine as well it will start. Of course if it's completely dead then yes, you're out of luck.
« Reply #20 on: May 02, 2013, 01:36:06 AM »
As per experience with a weak battery in a DC-CDI ... the scoot can't start when using the kick start... the horn and lights turn on, but can't create a spark to start the engine.... just can't...
garicao
« Reply #21 on: April 16, 2016, 09:04:51 PM »
Great tutorial!
Only thing I'd add is that (on the 2-stroke People 50, at least), the new belt width is 18mm and the used belt service limit is 17mm, as per shop manual (well, elsewhere in the manual it says limit is 16.5mm).  So, you can measure first, then know if belt replacement is necessary or optional.
Cheerios,
--garcia
"We're lost, but we're making good time."
mcdcfc3
« Reply #22 on: April 16, 2016, 11:03:04 PM »
Thanks for taking the trouble to post this. It's great to see how it's done but it's also made me more convinced to leave it to the experts such is my lack of skill with anything of a technical nature
Sent from my Nexus 7 using Tapatalk
paceneedsstides
« Reply #23 on: April 22, 2016, 12:28:12 AM »
Is this the people 50 you're going to sell to me cheap or donate to the Club on FB lol
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
MJR
« Reply #24 on: April 22, 2016, 06:19:01 AM »
3) Do I really need an air-impact wrench?  All I've got is elbow-grease. ;)
I made a holder bar for another project on my Burgman 650 that should work. It's just made from some metal bar and some bolts. It looks similar to this but just a Y shape.
« Last Edit: April 22, 2016, 06:21:30 AM by MJR »
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
mousejunks
« Reply #25 on: May 23, 2016, 10:30:22 AM »
I use an electric impact wrench for loosening, and the variator holding tool + hand wrench for tightening. Make sure you aren't tightening the variator face against the belt. At the same time I also clean out the rest of the case, last time a teaspoon of black dust came out of the rollers.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
Mr. Paul
« Reply #26 on: June 12, 2016, 12:35:31 AM »
It is not necessary to remove the rear clutch assembly. If you have a reasonably strong grip, you can put your hand in the rear pulley and move the faces apart as you pull the belt deeper as if it were in a higher gear. That gives you more than enough belt slack to remove the front variator and replace the belt. Hope that helps.
2009 Kymco People 150
1993 Honda Helix
« Reply #27 on: June 12, 2016, 01:09:29 AM »
A tip:
The cheap 12V impact wrench from Harbor Freight will break loose both of the CVT nuts using only a 12V scooter battery!
Surprised the heck out of me - thought I'd have to hook it to a non-running-car battery......but the scoot battery had enough poop to knock both of the Burgman 400 nuts loose.
