What ups mudfreek?
Weeping? do you mean seeping coolant out?.. Did you replace that gasket there? I know mine leaked there also, had to seal her up good with some rvt silicone.
Did you get the bearings/seal ALL the way in their spot? can you turn it by hand? not a free spin by any means.
![Cheesy :D](https://www.kymcoforum.com/Smileys/default/cheesy.gif)
Are you sure it's the W.P.? Make sure the "overflow" hole is open also.
Could something have gotten in behind the flywheel? even a grain of dirt
Did you happen to wiggle your crank any to see if any "play" is present on the crank bearing?
