Author Topic: HELP!!! Mods/Derestrictions = worse performance on 2011 Super 8 50cc 2T  (Read 35834 times)
Pimpy1
  • Mo Hoes Power
Re: HELP!!! Mods/Derestrictions = worse performance on 2011 Super 8 50cc 2T
« Reply #120 on: July 01, 2012, 12:00:55 AM »
I have to squeeze the belt together a couple of times in the middle to get the belt to slide off the boss after I pull the var outside plate off. It is all the way down and tight.
2011 Kymco Super 8 2t
2006 Kymco People 250
« Reply #121 on: July 01, 2012, 12:23:51 AM »
..thats normal, and the right thing to do, but  is your belt going all the way out on the driven pulley like in that pic?
Pimpy1
  • Mo Hoes Power
« Reply #122 on: July 01, 2012, 12:27:45 AM »
No. It is 1/4inch lower that in this pic. In the pic I had taken the belt off the boss and picked it up some.
« Reply #123 on: July 01, 2012, 12:31:25 AM »
..WHAT SIZE BELT IS THAT?
..i apologize, you prolly already said....
Pimpy1
  • Mo Hoes Power
« Reply #124 on: July 01, 2012, 12:34:27 AM »
Not sure yet. Stock OEM with 300 miles in it.
« Reply #125 on: July 01, 2012, 12:36:23 AM »
You should be able to read what's printed on it.
« Reply #126 on: July 01, 2012, 12:41:17 AM »
..oh, sh**!!...good pic!!...i see at least part of your problems...
..you have restricted driven pulleys...
..the  inner surface of the pulleys should taper down, uninteruppted, all the way to the driven pulley's "hub"...
« Last Edit: July 01, 2012, 12:46:02 AM by wordslinger »
Pimpy1
  • Mo Hoes Power
« Reply #127 on: July 01, 2012, 12:43:19 AM »
Will check size tomorrow. Was 102 here today and dark now. Not up to taking the cover off tonight while fighting off 1000 mosquitoes. Thanks for getting back though.
« Reply #128 on: July 01, 2012, 12:44:27 AM »
..it was 102 on my porch when i got home from work...
..brought nina inside....
Pimpy1
  • Mo Hoes Power
« Reply #129 on: July 01, 2012, 12:45:11 AM »
..you have restristed driven pulleys...
..the  inner diameter of the pulleys should taper down, uninteruppted, all the way to the driven pulley's "hub"...
Yes. Just one more kick in the nuts from Kymco.
« Reply #130 on: July 01, 2012, 12:46:19 AM »
She tends to get the vapors...
Pimpy1
  • Mo Hoes Power
« Reply #131 on: July 01, 2012, 12:49:39 AM »
Says Harriet Oleson.
« Reply #132 on: July 01, 2012, 12:50:24 AM »
She tends to get the vapors.....
..dang, yeah!! she does!!...she was trending rich at 85 degrees...
..102 means 125 degrees on th road, easy...
..running quite rich....
Pimpy1
  • Mo Hoes Power
« Reply #134 on: July 01, 2012, 01:01:24 AM »
