Author Topic: HELP!!! Mods/Derestrictions = worse performance on 2011 Super 8 50cc 2T  (Read 35831 times)
Re: HELP!!! Mods/Derestrictions = worse performance on 2011 Super 8 50cc 2T
« Reply #135 on: July 01, 2012, 01:08:51 AM »
Feel ya! Don't start counting...
« Reply #136 on: July 01, 2012, 01:23:40 AM »
...how far you really want to go?...
Pimpy1
  • Mo Hoes Power
« Reply #137 on: July 01, 2012, 01:30:21 AM »
I just wanted to get the scoot so there were no added restrictions. My friend in Germany just had to change his exhaust, up-jetted and added a free flow filter and now can go 87 kph on flats.
Why in the funk does Kymco hide all this shiiit for USA buyers.  :-[
2011 Kymco Super 8 2t
2006 Kymco People 250
« Reply #138 on: July 01, 2012, 01:35:44 AM »
..they just tryin to sell scoots...
..us speed laws necessitates that they restrict their scoots...if they want a good share of the market...
..too bad they cost a bit more, or they would be flooding the us market...
« Reply #139 on: July 01, 2012, 01:37:05 AM »
It's the U.S. laws that restricts everything..
Pimpy1
  • Mo Hoes Power
« Reply #140 on: July 01, 2012, 01:40:46 AM »
Yes but could they not just restrict the drive boss and the jet. Not the var, the exhaust, the rear pulleys, the belt length and on and on.  :'(
« Reply #141 on: July 01, 2012, 01:45:18 AM »
..they just try to keep a balance...
..such as you too will strive for as you make your performance mods...
ill_eagle94
« Reply #142 on: July 01, 2012, 01:52:05 AM »
I have to squeeze the belt together a couple of times in the middle to get the belt to slide off the boss after I pull the var outside plate off. It is all the way down and tight.
Usually I just squeeze on the outside of the clutch pulley and it stays loose enough to pop the belt off.
I'm using the stock belt too.
What are you guys running for aftermarket belts?
EDIT: Noticed the scoot runs a lot quicker when it's 85-90 degrees out than when it's 55-60 degrees out too.
« Last Edit: July 01, 2012, 01:54:23 AM by ill_eagle94 »
2012 Honda Fit Sport
« Reply #143 on: July 01, 2012, 02:00:32 AM »
..if you run a free flow filter, and a pipe...i've found a jet change every 30 degrees could be necessary, for "optimum performance"..
..we all dont have time for all that, so find that jet that gets you along the best in your seasonal tem/humidity range...
ill_eagle94
« Reply #144 on: July 01, 2012, 02:30:20 AM »
Well, I'm running the stock filter, pipe, and airbox. I'm afraid to remove the airbox and put my filter on without jetting, and I don't want to jet until I do the pipe too.
Pimpy1
  • Mo Hoes Power
« Reply #145 on: July 01, 2012, 03:29:22 AM »
@ ill_eagle94 - I put my stock Var back on and the scoot runs almost as fast as with the Malossi Variator but no more belt dust. I noticed you were having the same issues with burning your belt up. That stopped the dust. Thought you might want to know.
« Reply #146 on: July 01, 2012, 05:47:55 AM »
Because the Malossi is trying much harder to close the pulley with a short belt. Its a stronger var.
Pimpy1
  • Mo Hoes Power
« Reply #147 on: July 01, 2012, 04:07:44 PM »
The belt on my scoot is a kymco 23100 keb7 bando. That belt is stock on most Kymco 50 scooters. I guess it is just the restricted driven pulley stopping the belt from going up to level with the pulley instead of a 1/2 inch from top.
ill_eagle94
« Reply #148 on: July 08, 2012, 02:12:57 AM »
Ordered a gallon of Amsoil Dominator oil. 38 bucks shipped. Saves me 10 dollars over the same amount of Royal Purple and supposedly is the cats ass!
« Reply #149 on: July 08, 2012, 03:45:18 AM »
Try these guys... I get Golden Spectro 32:1 Platinum for 6 a pint. 1/2 the cost of anywhere else.  http://www.performanceoilstore.com/
