Author Topic: HELP!!! Mods/Derestrictions = worse performance on 2011 Super 8 50cc 2T  (Read 35830 times)
...the space between the pulleys should taper all the way down to the torque driver...like this pic
..click on pic for larger view...
..here's a restricted pulley..
..my s9s both had it, as well as my 2005 people..
..neither of my a50s were restricted, nor was my 2001 people...
..i cant remember if the 03 ppl had it or not...think it did...
« Last Edit: June 26, 2012, 02:46:29 AM by wordslinger »
From how low the belt sits at rest I would bet the pulley restriction is the case.
Pimpy1
  • Mo Hoes Power
I never thought to look for a restriction on the back set of pulleys. I will have to check mine also. I have sooo much more belt dust since I installed that new var on my super 8.  :-\
2011 Kymco Super 8 2t
2006 Kymco People 250
Check how it sits at rest. It has to be equal to the rear pulley tops, and snug on the actual drive boss. They wear faster as they get smaller.
..yup, and the dark belt markings and "dust" way out on the drive face....
..shows that the belt ain't getting all the way down in the driven pulleys...
..it's getting loose, and creating that residue...
..thatsa good 5-10mph loss off top end...
« Last Edit: June 26, 2012, 02:55:59 AM by wordslinger »
ill_eagle94
Once it stops raining, I'll pull the cover off and have a look inside there. If it's restricted, where do I look to get one that isn't?
2012 Honda Fit Sport
http://www.racingplanetusa.com/clutch-pulley-assy-clutch-torque-converter-assy-naraku-107mm-p-3888-1.html?cPath=2_18_108&sessID=a93952c7195f45279a16cbffd2d442f5
..this issa good site..annd this is the naraku clutch that is close to oem...
..they have other 107mm clutches, but i bought this one to get the unrestricted driven pulleys...
ill_eagle94
Thanks! I'll keep it in mind if I do have the little hump!
Pimpy1
  • Mo Hoes Power
Usually I like a "little hump" but in this case I am going to be pissed if Kymco found one more way to slow my scoot down.  :'(
ill_eagle94
Re: HELP!!! Mods/Derestrictions = worse performance on 2011 Super 8 50cc 2T
« Reply #100 on: June 28, 2012, 12:36:02 AM »
I wonder if it's there, if I could sand it down on a rotary tool of some sort.
« Reply #101 on: June 28, 2012, 01:30:05 AM »
..NO!    you can not..
« Last Edit: June 28, 2012, 03:58:01 AM by wordslinger »
Pimpy1
  • Mo Hoes Power
« Reply #102 on: June 29, 2012, 12:07:54 AM »
Took a pic of the rear pulleys on my super 8. The belt stops about a 1/2 inch below level with pulleys. I guess mine has the restriction.  >:(
« Reply #103 on: June 29, 2012, 03:10:09 AM »
Ideally, at what point should the belt stop? Level with the pulley? a bit above the pulley? a little bit below?
« Reply #104 on: June 29, 2012, 04:36:26 AM »
Up to 2mm above. Never below. Sometimes a wider belt is needed if you keep the restricted pulley set.
