Did you miss your
activation email
Scooters - 125 to 300
People s200
Tool for Rear Shock Adjustment
Topic: Tool for Rear Shock Adjustment (Read 2602 times)
azscootin
AZ - But it's a Dry Heat!
Newbie
September 08, 2011, 03:11:47 AM »
Hi all;
Need to adjust the rear shocks and the manual states making the changes via a tool. Anyone know what this "tool" is or if there ad hoc piece that can be used to adjust the rear coil shocks?
TIA
JustWantToRide
Sr. Member
Re: Tool for Rear Shock Adjustment
September 08, 2011, 03:39:45 AM »
They are made to accept a spanner wrench - but I just use my hands.
Spanner wrenches are inexpensive and easy to find. Match the diameter of the shock to the inside curve of the wrench - anything close will work. You could always put a stubby screwdriver into one of the holes and turn it that way.
2009 Xciting 500Ri
52mpg so far
TechGuy
September 08, 2011, 04:01:41 AM »
Just put on a leather glove and adjust it with your hand. I suggest you do it while the bike is on the center stand.
RBSC 2010 Russian to Ride Photos
Rides of March 2010 800+ Mile Weekend Rally Ride
RBSC 2009 Tahoe Photos
azscootin
Newbie
Reply #3 on:
September 08, 2011, 04:14:20 PM »
Thanks for the replies, will give it a try.
2leftthumbs
Newbie
Reply #4 on:
August 22, 2014, 09:45:59 PM »
In the manual the suggest puttin the screwdriver the furnish in the hole to turn it.
bluesin
2012 DT 300i
Reply #5 on:
August 23, 2014, 11:49:07 AM »
Did you look for the small tool kit that should have come with bike ( originally ) ?
Should be wrapped in a blue plastic case and strapped to the bottom of the seat .
"There is a Fifth Dimension beyond which is known to Man. It is a Dimension as vast as Space and as timeless as Infinity......It is an area which we call 'The Twilight Zone' . "Rod Serling
Back
