Get this scooter fans. I've been whining cause my speedometer quit working for no good
reason a few days ago. Well Sunday morning I turn on the key and the needle swings all
the way clockwise and all the way back. So I'm thinking that's a strange one. I took off
for a ride and the speedometer has worked ever since. Go figure. Ride safe scooter friends.
Most likely... hm... I can`t find the right word in English.
Maybe something like "cold weld"?
Contact between electronic components that is established when atmospheric conditions are favorable (moisture,pressure) and it gets broken under normal conditions... usually due to mechanical movement of components/board and/or poor component welding quality.
I had such issue with my LCD tachometer on Beverly. It was first fixed by skilled person re-welding using microscope, died again (due to corrosion) and then I had it replaced with another unit taken from scrapped bike. That LCD tacho was around 120 US$ new...
