Author Topic: Agility SQUEEK!!  (Read 821 times)
Dexity
Agility SQUEEK!!
« on: September 09, 2011, 07:38:17 PM »
My front wheel squeeks really bad, naturally I can only hear it at slow speeds.  Are there any grease zerks on these?  It is a 08 agility 50.  I have looked over it qutie a bit without taking off any of the plasticware.  The front breaks also have a horrible squeek, so I just do not use them.  Is it recommended to regrease all the moving parts?  If so is there instructions on how to do so anywhere?  I live in a land where no one knows anything about these scoots, ingrates I tell ya!  I have no experience with bikes before this one, so any amount of info could assist me.
jezyg
  • Agility 50 2011 and SEAT Leon FR TSi 211
    • UK Police Books
Re: Agility SQUEEK!!
« Reply #1 on: September 09, 2011, 08:15:09 PM »
Squeaky brakes could be just dust build up and a good pressure wash may clear it off. Failing that some copper grease on the pads should do the trick.
As for the front wheel does sound like the bearings that are either lacking grease or a cracked ball bearing within the bearing. Does need the front wheel off and a bearing puller tool to get at them and then check and re grease. Have you just tried spraying some WD 40 around the bearing area as a "quick see if it works" solution?
2011 Agility 50
2011 SEAT Leon FR TSi 211
http://www.lulu.com/spotlight/Policebooks
