Author Topic: Strange noise and loose pipe??  (Read 2787 times)
whiteknight
  • ..Knight Tweed..
« on: September 19, 2011, 01:33:28 AM »
hello all
im hearing some weird noises coming from the engine/exhaust? i can tell you exactly what it sounds like, its like the sound you would get from a turbo wastegate and it only happens when i let off the throttle at about 40-45 mph.
also i have a loose piece of tubing near my back wheel, its been chewed to sh**e and all i can say is it comes from the head, you can see it if you look through the air hole under the seat.
thanks
bmcafee
Re: Strange noise and loose pipe??
« Reply #1 on: September 19, 2011, 01:44:59 AM »
could the tube be a vacume line?? I iwould replace it and then go from there.
« Reply #2 on: September 19, 2011, 01:48:02 AM »
maybe your muffler just needs to be tighten .
sidthesloth
  • Kymco ZX50
« Reply #3 on: September 19, 2011, 04:47:24 AM »
Sounds like an exhaust leak, Streido had an issue with his EGR pipe rusting through. I will see if I can find a link to a digram and see if it is the pipe you are talking about.
sidthesloth
  • Kymco ZX50
« Reply #4 on: September 19, 2011, 04:58:28 AM »
Here is a link to stadium yamaha's exploded view of the agility 50 cylinder head, see if the pipe is on that diagram. If you look to the top of the page, there is a drop down panel which has the views for the other sections of the scoot, have fun.
http://www.stadiumyamaha.com/pages/OemParts?aribrand=KYM#/Kymco_USA/Agility_50/Cylinder_Head/2K03030005/2K03030007
whiteknight
  • ..Knight Tweed..
« Reply #5 on: September 22, 2011, 02:48:49 AM »
thanks for the link man, but unfortunately it didnt show what the pipe was, which was kind of a bummer. so i have decided...im gonna re-build the engine from the ground up (cylinder, piston, crank, cam ect. ect.) so with the failing chinese engine on the way out i will build a 50cc race engine. wish me luck guys lmao
streido
« Reply #6 on: September 22, 2011, 10:05:24 PM »
Nah sid i dont think its the same issue i had. Mine was the chrome pipe at the front of the engine, no where near the back wheel. Can you put up a photo WK?
 My small bore chrome u shape pipe on the too if the valve cover was rusted thro, sounded like a small exhaust leak and was noisier, kind if tick noise.
Does it still run ok or do you have any other issues?
Chaos is my co-pilot.
Kenho21
« Reply #7 on: September 23, 2011, 03:55:02 AM »
These engines aren't chinese, they're taiwanese... Big difference
whiteknight
  • ..Knight Tweed..
« Reply #8 on: September 23, 2011, 12:35:45 PM »
i can try and get a photo on here, i am experiancing a slight drop in power and its quite sluggish when moving off (have to flutter the throttle) all i know about the tube is its rubber and it used to hang down near the rear wheel and its attached to the head. as i said i will try and get some photos on here to give a clearer picture (bad photo pun)
thanks for the replys so far
streido
« Reply #9 on: September 23, 2011, 01:15:21 PM »
I just had a quick look on mine and the only hose i saw that sounds like it may be the one is a small black rubber hose coming from under my seat area and goes to the back of the airbox by the rear wheel. It looks maybe 10-15mm wide, goes to an "L" elbow on the back of my airbox. Maybe that? It is the nearest hose that looks like it could hit the back wheel if it had come off.
woodcutter
« Reply #10 on: September 23, 2011, 07:12:27 PM »
sounds like it's a crankcase breather and it's a part of engine overheat protection.
whiteknight
  • ..Knight Tweed..
« Reply #11 on: September 25, 2011, 03:08:30 AM »
yea thats the pipe i found, it has been chewed up by the rear tyre, thats how i originaly found it because of the rubber marks on the side wall.
will get it sorted asap.
do well  :D
