Author Topic: Transmittion Problem MXU 300  (Read 6732 times)
bhuber28
« on: January 08, 2009, 06:22:01 PM »
During our great Northwest snow I took out my 2006 MXU 300 to play in the snow. The quad only has 22 hours on it. While going round and round in the snow the transmittion or something would kick out of gear, come to a near stop and then grind its way back in. It will only do it if its in high gear. I have checked the shift rod and netural position and it is OK. Any one have any ideas??
Kent
Re: Transmittion Problem MXU 300
« Reply #1 on: January 27, 2009, 07:38:04 PM »
Hi!
I had similar problems. They were all caused by loosen bolt from here :
http://kuvablogi.com/nayta/1133811/
Shift fork had so much loose that it sometimes dropped gear of.
Intab
« Reply #2 on: May 27, 2021, 09:48:00 PM »
Hi!what was wrong when high gear jumps
yerbito
« Reply #3 on: December 08, 2023, 10:23:47 PM »
Hi!
Hi. Link doesnt work. Can you tell me more about that bolt?
Thanks you
