Author Topic: Roller weights?  (Read 13601 times)
streido
Re: Roller weights?
« Reply #15 on: October 10, 2011, 08:29:43 PM »
I have a couple of links to help explain, will look them out later and post them up for you.
Chaos is my co-pilot.
kanbisk
Roller weights?
« Reply #16 on: October 11, 2011, 05:50:32 PM »
Hi,
How can we find out weights of rollers? By weighing them, they are colour coded or does it says on them ?
Thanks
Agility 50 4 stroke 2008
streido
Re: Roller weights?
« Reply #17 on: October 11, 2011, 06:23:55 PM »
Suppose you can weigh them if you have accurate scales. Stock is 6.5g. If you order a set you just ask for whatever weight you want, i.e 5.5g, 6g, 6.5g, etc. The size you need is 16x13 then the weight you need. So for Stock you want 16x13, 6.5g rollers.
None of mine have ever had a weight stamped on them. They have a brass insert covered by plastic/nylon stuff, the brass is thicker so heavier in the heavier weights. If you look at them on the ends you can tell if one is heavier or lighter by comparing the thickness of this brass.
« Last Edit: October 11, 2011, 06:28:39 PM by streido »
mhaseebalam
Re: Roller weights?
« Reply #18 on: November 12, 2019, 05:43:21 PM »
Im a beginner and would like to change the variator of my  agility 50. Do I need to remove the body parts in order to be able to remove the cvt cover? As I can not reach one of the bolts using a rachet.
eamartin
Re: Roller weights?
« Reply #19 on: November 12, 2019, 09:39:31 PM »
I have a 2011 Agility 50.  I just looked at the CVT cover (which I have never removed) and it appears that I can get to all the bolts with a ratchet and an extension.  Which bolt concerns you?
