Author Topic: spark plug  (Read 1965 times)
spark plug
« on: October 10, 2011, 12:58:32 AM »
Was geting ready for a long scoot ride this morning but the scoot didnot tune over.So I had to take my wifes gy6 scoot .When I got back from the ride I found out it was the spark plug was bad. That was kinda fast for wearing down a plug is there a plug out there that just might last longer then a ngk c7hsa.
REDKYMCO
Re: spark plug
« Reply #1 on: October 10, 2011, 08:42:16 PM »
Is the plug showing signs of heat damage in my experiance when a spark plug wears out fast its usualy running too hot are you sure you are not running to leen
IF IT IS NOT BROKE DONT FIX IT:)
juice
Re: spark plug
« Reply #2 on: October 10, 2011, 09:37:45 PM »
The iridium plugs are supposed to last longer . I have used them in all of my scooters and have never had one go bad or foul . Good luck .
Re: spark plug
« Reply #3 on: October 10, 2011, 10:28:20 PM »
No its not running leen. guess its just normale wear 2 plugs in one year ate to bad.
kanbisk
Re: spark plug
« Reply #4 on: October 15, 2011, 05:13:53 PM »
Hi,
isnt there any other type plug we can use then ngk c7hsa?
I see same plug on ebay.uk for £1.00 and here (Norway) cost about £7.50    ???
LATERS
Agility 50 4 stroke 2008
streido
Re: spark plug
« Reply #5 on: October 15, 2011, 08:43:50 PM »
Hi,
LATERS
No.  :D
Well unless you want iridium but that will be more expensive.
Chaos is my co-pilot.
kanbisk
Re: spark plug
« Reply #6 on: October 15, 2011, 09:04:33 PM »
Not iridium, just a standard NGK C7hsa.
LATERS
juice
Re: spark plug
« Reply #7 on: October 15, 2011, 09:37:17 PM »
According to the cross reference chart available on the sparkplugs.com website- autolite 4194 , champion z94 , denso u22fs-2 . Good luck .
kanbisk
Re: spark plug
« Reply #8 on: October 16, 2011, 11:05:36 AM »
yeah, found some NGK's on ebay.uk for £1.00 each plus p&p. I order'd 3    ;)
LATERS
Resolve
Re: spark plug
« Reply #9 on: October 17, 2011, 02:13:22 PM »
The NGK 4629 is a standard copper plug and a cross reference to the C7HSA and I have been using it with no issues. Only like a couple of buck at my local autopart store
kanbisk
Re: spark plug
« Reply #10 on: October 17, 2011, 05:44:04 PM »
good to know. Thanks.
LATERS
kanbisk
Re: spark plug
« Reply #11 on: October 24, 2011, 11:14:57 AM »
Hi,
just wondering what is the difference between C7HSA and CR7HSA.
LATERS
