Author Topic: zx50 position bulb  (Read 3640 times)
rigpa
zx50 position bulb
« on: October 11, 2011, 07:07:44 PM »
Hello good people,
I have a zx50 '04 and my front left position bulb has gone out.  the right one still works.  these are the running lights not the hi beam which hasn't worked in a couple of years.  I'd like to replace the left position bulb.  the OEM part number says it is a 12v 5w bulb.  Is this something i can pick up at an auto parts store or do i need to special order through one of the scooter stores.  I know nothing about the electrical wiring on these things.  is there a book I can read or some place online to help me understand scooter wiring. Thanks loads!
Linda
sidthesloth
  • Kymco ZX50
re: oko carb 'n bits
« Reply #1 on: October 11, 2011, 07:29:14 PM »
I am not sure if they are a wedge type bulb but, either way you should be able to get them at an auto parts store. Might be worth replacing the headlight bulb while you are at it. I don't know what the part no. is for the stock headlight bulb but a BA20D super bright halogen bulb fits straight in and is a big improvement. Just make sure it is a 35/35 watt bulb.
rigpa
Re: zx50 position bulb
« Reply #2 on: October 11, 2011, 07:37:45 PM »
the time i had the headlight checked the bulb was working.  so i think it's something else.
do i remove the handlebar cover to access the running light bulb for replacing.  also are these single or dual filaments and what is the diff?
sidthesloth
  • Kymco ZX50
« Reply #3 on: October 11, 2011, 07:54:42 PM »
Yes, from memory you remove the cover and you have access to them. Not sure, but I think they would be single filament, a dual filanent bulb is for a light with two functions, like a tail/brake light.
How has your scooter been running?
rigpa
« Reply #4 on: October 11, 2011, 07:59:33 PM »
Hi Sid,
She's been running okay.  No probs with the piston, etc.  I changed the rollers over to 8.5 grams and this is making her way slower on the hills, which is a sad face.  I didn't think a gram diff would make that much difference.  The belt is relatively new as is the muffler.
Linda
sidthesloth
  • Kymco ZX50
« Reply #5 on: October 11, 2011, 08:04:46 PM »
While you have it open, check that the blue and white wires from the headlight to the plug are clean and plugged in tight. If yours has high/low beam switch, then the wires will go to the switch and one wire will go from the switch to the plug.
rigpa
« Reply #6 on: October 11, 2011, 08:13:02 PM »
thanks.  and if i need a new switch or relay how will i know?  I do have the hi/lo switch.  i don't understand all the wiring stuff and am finding it hard to find info for novices.
rigpa
« Reply #7 on: October 12, 2011, 02:00:34 PM »
so, after work last night, i had both running lights.  maybe loose wires or connection.
sidthesloth
  • Kymco ZX50
Position bulb
« Reply #8 on: October 12, 2011, 02:32:35 PM »
Could be a dirty connection, or a bulb on it's way out.
rigpa
« Reply #9 on: October 12, 2011, 02:46:46 PM »
do i clean that connection with sandpaper?
sidthesloth
  • Kymco ZX50
« Reply #10 on: October 12, 2011, 03:15:31 PM »
Yes, sand paper, emery cloth or emery board. WD40 is also good as well.
On a side note, does your scoot have a high beam light on the dash? If so, could you post a pic of it please?
rigpa
« Reply #11 on: October 12, 2011, 03:59:00 PM »
I'll take a pic within an hour or so.
rigpa
« Reply #12 on: October 12, 2011, 04:15:37 PM »
are these wires crimped or soldered at the connector?  if it's loose wiring do i need a new connector?  if so, do you know what kind?  everything is stock.
sidthesloth
  • Kymco ZX50
« Reply #13 on: October 12, 2011, 05:25:27 PM »
The wires ard crimped in the terminals, it would be those connectors that may be dirty.
rigpa
« Reply #14 on: October 12, 2011, 05:36:53 PM »
dash pic
