Author Topic: S125 sparkno spark  (Read 834 times)
jomama
S125 sparkno spark
« on: October 12, 2011, 11:10:09 PM »
OK lads here we go, on my 08 S125 i was having a problem starting which i thought was humidity realted. Sometimes it would fire right up and other times just spin over. After putting it in a warm heated garage i got the same results. Replaced the plug,checked coil wires,plug cap for resistance and fully charged the bat. Pulled and grounded the plug and it spins over but only produces a spark when the starter button is released and once in a while not even then. It does not fire on the kicker either. Also checked and cleaned the fuses. Any help will be greatly appreciated.
PS I wanted to get at the key switch and other connections but cannot figure out how to access them without wrecking the plastic.
