Author Topic: Tire Pressure  (Read 2896 times)
jimpote03
Tire Pressure
« on: October 20, 2011, 02:35:14 PM »
I recently had to replace my rear tire but had a shop mount it on the rim. Now the front tire is low. I checked the service manual and found the tire pressures are all in metric!!! Since I don't know how to make the conversion, can anyone tell me what the English equivalent might be?
Jim P
Sideshow
  • Reading, PA
    • My web site
Re: Tire Pressure
« Reply #1 on: October 20, 2011, 02:47:50 PM »
jimpote03
Re: Tire Pressure
« Reply #2 on: October 20, 2011, 06:07:33 PM »
Doesn't really help. The user manual expresses the tire pressure are kgf/cm2. I think that's kilograms of force per sq centimeter. The actual numbers are front - 1.75 kgf/cm2; rear 2.0 kgm/cm2
Any other ideas. Maybe I should just call my local dealer but this is more fun.
jimpote03
Re: Tire Pressure
« Reply #3 on: October 20, 2011, 06:14:49 PM »
I just found the conversion formula on line at http://www.convert-me.com/en/convert/units/pressure/pressure.kgcmsq.en.html. One kg per sq. centimeter = 14.22 PSI. Learned something new today.
scootergrisen
    • scootergrisen
Re: Tire Pressure
« Reply #4 on: October 20, 2011, 09:12:00 PM »
soberpath
Re: Tire Pressure
« Reply #5 on: October 21, 2011, 03:30:07 AM »
All you have to do is type it into google.
ChandlerScoot
Re: Tire Pressure
« Reply #6 on: October 21, 2011, 03:08:41 PM »
I usually go with what is marked on the tire as a basis. The markings should tell you the maximum air pressure required by the tire manufacturer in both metric and standard...
Simon
2009 Kymco Xciting Ri With no mods.
soberpath
Re: Tire Pressure
« Reply #7 on: October 21, 2011, 04:13:57 PM »
I believe it is either 25 or 25.5 psi for the front and 29-31 for the back, i have it at 31 on the back tire because im a very large fella and they recommend 31 for 2 up. With me on it its pretty much 2 up lol.
fshfindr
Re: Tire Pressure
« Reply #8 on: October 21, 2011, 11:36:17 PM »
1.75kg/cm2 = 24.88 psi and 2kg/cm2 = 24.44psi from my converter app.[/s]
Ooops, so sorry.  Good catch Scooterdude.
  1.75kg/cm2 = 24.88 psi and 2kg/cm2 = 28.44psi
« Last Edit: October 22, 2011, 02:43:50 PM by fshfindr »
Richard L. in Bellmawr
old geezer
Re: Tire Pressure
« Reply #9 on: October 22, 2011, 12:44:24 AM »
Now how can 2 be less than 1.75???
http://www.worldwidemetric.com/measurements.html
« Last Edit: October 22, 2011, 12:58:18 AM by scooterdude »
