Author Topic: Newbie to Kymco, but not atv's  (Read 1736 times)
XCnasty
  • Put on a helmet
  • '10 MXU 500IRS LE
    • RRMT Inc.
« on: October 20, 2011, 08:51:32 PM »
Hello, my name is Ben. Have a '10 MXU500 IRS LE. Have a starting prob, after a trip. E-start does not work pull start did twice. Now it will not stay running for me to test the battery. Makes a clicking sound on the solenoid. Hope it is not the stator. Any suggestions?
"Run what you brung"
101st Airborne Assualt
MEDEVAC Cpt.& CRNA
"Screaming Eagles"
Blustik913
Re: Newbie to Kymco, but not atv's
« Reply #1 on: January 04, 2012, 09:32:37 PM »
I have te same bike and have had that issue before. Did you go in water? 1st pull your plug wire and
Make sure it's clean then try again. Also make sure your air box has nothing in it. If it still won't start pull your plug (use the tool in ur kit to get it out) and ground to the frame and hit te button. If it sparks then you probably don't have enough starting amps to crank it and will need either a new battery or try charging the one you got. Let me know if you need anymore help. I've ran my through the test and can honestly say its holding up good. It's been tore down and put back together several times from flipping in pOnds and stuff
2010 mxu 500 IRS le
Maxxis Zilla 26's
Custom snorkels
Bumpers being made currently
