Author Topic: Plug and Play LED Flasher relay for $8.95  (Read 1580 times)
JustWantToRide
« on: November 01, 2011, 11:36:47 PM »
This LED flasher relay is only a 2 wire - but it plugs right into the stock plug and works great.  The hole in the plastic mounting tab needs to be opened up a bit to mount it where the stock relay was - but that's simple.  The only downside is that it doesn't make noise like the stock one.  I might have to get a little buzzer from Radio Shack if I miss it much...
LF1-S-FLAT: Universal Motorcycle Flasher  $8.95
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Ftail-brake-turn.html%23flasher
I paid $19.95 from Custom LED's for mine - then a friend showed me this one which is identical.
« Last Edit: November 01, 2011, 11:51:36 PM by JustWantToRide »
2009 Xciting 500Ri
   52mpg so far
dont_tread_on_me
Re: Plug and Play LED Flasher relay for $8.95
« Reply #1 on: June 13, 2012, 09:49:02 AM »
  Did you replace your stock bulbs with LED ones and if so,where did you get them.Do they plug right in or is modification required? This looks like the plug on a super 9,any idea if it will fit?
JustWantToRide
« Reply #2 on: June 22, 2012, 04:31:33 PM »
I replaced the bulbs with leds, and added majicblinker modules so the signals are on, then blink off.  This flasher relay is a generic type item so I would think it would fit "plug and play" on your scoot also.  Check your current bulbs - the Xciting has different bulbs front to back.  The 2 links I have in this post have had the brightest bulbs at the best prices that I've found.  I have other posts that list the exact bulbs I used - and they are much brighter than the bulbs that I've seen other people buy.  Your super9 will probably use the same size bulbs - you just need to check if the alignment buttons are directly opposed or closer to each other (European or US), or a mix like mine were.
2009 Xciting 500Ri
   52mpg so far
