Did you miss your
activation email
Scooters - Big Bore
Xciting 500
Underseat Light Issues
Topic: Underseat Light Issues (Read 1565 times)
Zorce
Newbie
November 08, 2011, 05:11:51 AM »
My light under the seat has never worked. The bulb looks ok but I replaced it anyway and still nothing. Is there a fuse somewhere for this particular light? Anything else that I am missing?
2007 Kymco Xciting 500
1981 Honda GL500 Silverwing
ts1
Re: Underseat Light Issues
November 08, 2011, 10:06:33 AM »
I don't remember a dedicated fuse for the bulb.
But I disconnected the wiring, because the bulb drained my battery if the compartment wasn't firmly closed.
Do you have a multimeter? Check for voltage and the wiring.
ChandlerScoot
Full Member
November 08, 2011, 03:39:07 PM »
Check to see if the "Met-in" indicator is lit on the dash if the seat is up. If it is lit, then the issue may be at the seat switch. If it not lit, then the circuit will need diagnosing.
Simon
2009 Kymco Xciting Ri With no mods.
JustWantToRide
Sr. Member
Reply #3 on:
November 08, 2011, 04:11:36 PM »
If the Met-in light is on when the seat is open - then remove the underseat tub that the light is connected to and make sure that the connector for the light is seated properly (disconnect it and reconnect it). If the Met-in kight on the dash (lower right) isn't lit when the seat is open - then remove the tub and check the sensor's connector is seated properly.
The bulb might look okay and still be bad. I'd buy a new mini wedge LED bulb to replace it with. If it isn't the problem - then having an LED in it will give you more time to notice it is on before it kills your battery.
2009 Xciting 500Ri
52mpg so far
drifter
Full Member
Twist n' Go Power!!!
Reply #4 on:
November 22, 2011, 06:36:42 AM »
yup sometimes it gets unplugged. that light is useless if your compartment is full so i installed an LED strip rigt under the seat.
"it's more fun to ride a slow bike fast than to ride a fast bike slow!"
Zorce
Newbie
Reply #5 on:
November 27, 2011, 01:32:19 AM »
Yeah, after removing compartment I saw that the light and the phone charger outlet were not even plugged in. They are now and issue is fixed.
Back
