Author Topic: Brake lever adjustment?  (Read 1244 times)
Gerry O
« on: November 15, 2011, 12:33:27 AM »
Hi, just bought a 250S a few weeks ago and really don't like the angle of the brake levers.  I would like to angle them a bit more down.  Does anyone know if this can be done?  Also is there some tricks to getting the plastic covers off from around the handlebars?  I took out all the screws and the windscreen, mirrors, but it doesn't want to move?  I downloaded the manual, but that is a bit of a joke as far as any detailed directions go.
Gerry O
Re: Brake lever adjustment?
« Reply #1 on: November 23, 2011, 12:11:21 AM »
Hmmn, not quite the wealth of information on this subject as I had hoped for?
 Does this mean nobody has taken off the plastic covers to adjust their brake lever angle?
Or is it that no-one can figure out how to take off the plastic covers??
fshfindr
« Reply #2 on: November 23, 2011, 12:29:24 AM »
Pretty sure my Yager levers are not adjustable.
Richard L. in Bellmawr
old geezer
« Reply #3 on: November 23, 2011, 04:23:30 AM »
I believe they are pinned so the location is fixed.
eugenec
« Reply #4 on: December 16, 2011, 05:33:47 AM »
You will have to file away the key on the bottom clamp to be able to rotate the brake levers. Not hard to do with a dremel tool, but keep in mind the mirrors are installed on the brake lever housing.
