Did you miss your
activation email
Scooters - 50cc
People 50
Done everthing I could...still no spark
Topic: Done everthing I could...still no spark (Read 960 times)
metrojet
Newbie
November 15, 2011, 08:58:57 PM »
I have a people 50cc 2stroke,has no spark,installed new DC-CDI,Rectifier,coil,stator.checked continuity on all wires all seems good....though I notice output at the stator (yellow-white wire)is 1.2vac should it be more.
undead primate
Re: Done everthing I could...still no spark
November 16, 2011, 08:29:39 PM »
...do you have continuity thru your kill switch and brake switch circuits?..
..do you have a good tight connection at the plug?
..had a similar issue and the tab was missing from the connector...
peace
metrojet
Newbie
November 16, 2011, 10:23:24 PM »
yes continuity on all wires not only kill switch,checked from stator to rect. and dc-cdi........Just checked the stator output (isolated)1.6Vac.But its new should it be at least under 18Vac.
metrojet
Newbie
Reply #3 on:
November 16, 2011, 10:25:33 PM »
oh yes I redid the connectors also.so I know its has good contact.
Back
