Author Topic: Went down Sunday night  (Read 3795 times)
fshfindr
Re: Went down Sunday night
« Reply #15 on: November 27, 2011, 07:10:48 PM »
Last, a poster above mentioned about how he normally takes a turn on the inside and when he didn't he had close call. Really the proper way to take a take a turn ( I call them corners) is to start on the outside and gradually head toward the inside until you hit the apex and just gradually head towards the outside after the apex. Braking is all done before the corner although racers use trail braking right up to the apex.
There are many great books out there like Total Controlrol by Lee Parks. Lee covers many of the things that riders can use to save our necks. I would suggest with the on set of winter for some of you pick up a copy, it would make some good reading over the non riding season and would also make a very good Christmas present.
[/quote]
Yes, you should start your turn (corner) from the outside where you have the best view of what's in front of you.  However, you still should get to the inside (apex) of the curve after starting on the outside.  If you are cornering on the outside, you have less ability to get straight when necessary.  Also, I think we have all been there when a 4 (or more) wheeler takes a very wide turn and is on or over the centerline.  I try to be off the center when entering the corner, and get to the apex under full control and even stay tight depending on the curve.  I haven't read Lee but I do read "Proficient Motorcycling" by Hough in which he quotes Lee.
Still a Newb, Still Learning,
Richard L.
Richard L. in Bellmawr
nplenzick
    • Nick Plenzick Enterprises.com
« Reply #16 on: November 28, 2011, 02:42:46 AM »
Last, a poster above mentioned about how he normally takes a turn on the inside and when he didn't he had close call. Really the proper way to take a take a turn ( I call them corners) is to start on the outside and gradually head toward the inside until you hit the apex and just gradually headtowards the outside after the apex. Braking is all done before the corner although racers use trail braking right up to the apex.
Richard L.
I did mention about at the apex you should be towards the inside of the corner. I for one use pretty much all of my lane when appropriate when riding through the twisty stuff.  I think the biggest problem with riders and drivers is they simply apex to early, doing so pretty much puts your exit very wide into on coming traffic or getting your wheels off the pavement on exit/entrance ramps.
melodys39
« Reply #17 on: December 21, 2011, 12:06:43 AM »
Yeah, not any time to think, just grabbed the brakes. I don't even remember the sensation of falling over, just the sudden thump against the pavement.
I think my new practice around bicycles, joggers, walkers, etc. is to give a couple of honks on the horn to let 'em know I'm around.
I did pickup new helmet, jacket & boots today, so I'm ready when my scoot gets back.
Glad to hear that you picked up new safety gear! I'm a safety gal, and believe whole-heartedly in all safety gear. I've fallen over at stops before (foot went down on gravel), and just my gloves alone protected my hands from getting scraped up. My scooter doesn't move unless I have ALL of my gear on.
And I am so glad to hear that you are ok :)
'09 White Grandvista 250 "Dinky"
