Author Topic: winginman  (Read 834 times)
sissy mary
winginman
« on: November 19, 2011, 03:50:22 PM »
Please look at my last question on the head light bulbs from my previous post. I don't know if the H7 will work in my X500? Also, anyone else know of a better quality (as in more powerfull) bulb that will fit a stock X500 that will work, not over power the electrical system, and work or fit in the stock housing without melting it. Thanks in advance.
winginman
    • Accugen DNA Service
Re: winginman
« Reply #1 on: November 19, 2011, 07:30:21 PM »
The H7 is a single element bulb where the H4 is a double element that has both high and low beam and are not interchangeable.  I guess the jest is that a new bulb is going to be brighter than one that is several years old and has some time on it.  The more expensive bright white bulbs give a little more light but 30% more than a new standard bulb.  If you want a lot of light without increasing the wattage look at the HID stuff.  It's expensive but does put out a lot of light.  Now does anyone make a setup for the X500 I don't know.  Here is a link to a company that sells the duel beam setup for a motorcycle.  http://shop.hidcountry.com/Motorcycle-HID-Kits-s/198.htm  I have friends I ride with that use these on their BMW bikes and the light output is pretty impressive.
Jim
09 Kymco 500Ri (His)
04 Aprilia S500 (Hers)
01 Honda GL1800 (Ours)
DNA Paternity Testing www.accugendna.com
sissy mary
Re: winginman
« Reply #2 on: November 21, 2011, 12:31:47 AM »
Thanks, that explains alot.
