Author Topic: Variator  (Read 8788 times)
sissy mary
Re: Variator
« Reply #45 on: March 14, 2012, 12:57:00 PM »
Do they make them for the stock variator? And should you stay with stock weights, or go 1 gram higher like I did when I got the Dr Pulley's? :-* Also do an MPG study for us. :-*
Re: Variator
« Reply #46 on: March 15, 2012, 12:49:38 AM »
AWESOME!It sounds like they have the same "profile" as Dr. Pulley... Higher rpms at the same weight. Can't wait to hear more...
drifter
  • Twist n' Go Power!!!
Re: Variator
« Reply #47 on: March 15, 2012, 09:22:12 AM »
they sent me same weight as the stock malossi rollers and stock rollers. Haven't tested the stock pulley with th FR yet. As for the mpg n0t minding it yet but it drop significantly. Due to wot!
"it's more fun to ride a slow bike fast than to ride a fast bike slow!"
Scumeda3
  • I drive a 2009 Xciting Ri
Re: Variator
« Reply #48 on: April 12, 2012, 02:26:48 AM »
What's the latest on rollers?  I am looking for better mpg.  I seem to get @ 50mpg registering @75mph with some WOT.  I weigh about 200 w/gear.  Will heavier rollers do the trick?  I hear acceleration suffers when you do this.  Any info is apprectiated.
The reason I ask, I was reading the DT300 Forum and there are @100 posts for this subject.  Didn't read them all, but interesting stuff!
Re: Variator
« Reply #49 on: April 12, 2012, 03:15:57 AM »
If you went 1gr heavier you would wind up running 150rpm+ - less at the same speeds. You could do the math to get the optimum rpm/cruise ratio. That and a Hi Energy Ignition coil/iridium plug, and good fuel. You will gain quite a few mpg. I'd guess +10% at least.
