So I ordered a new variator cover/CVT Cover or what ever that cover is called that goes over the belt and variator. It all started with a few posts back where I mentioned I had cracked the metal casting while trying to kick start it one cold day.
Day 1: Using my old parts (kick start parts) I put them in the new cover, I have tension on the half moon and it makes contact and rotates great. I put it on and now my electric start is having trouble starting her up and when I put it on originally, one kick and it started. Now that I have kick started it, my electric start is working hard or not even working.
Day 2: one kick turned into 7 and electric start won't turn it. Once started with kick, I go to work. It sits for 9 hours and electric start won't turn it over and then took a lot of kicks to get it going, barely.
Got it home, let it sit and went to try it again. I kicked it start and I heard a metal bumping noise. I turn it off, and start it (hard) with the electric. Same noise. I take off cover and took out the contact spindle? that connects to the half moon. Cover back on and it my electric start was hard, turned it off and waited a minute and electric start fired it right up.
Okay, now the questions
![Smiley :)](https://www.kymcoforum.com/Smileys/default/smiley.gif)
I appreciate any help.
I ordered it from my Scooter Shop and it appears to be an exact copy except for some extra markings on the inside that bear no weight on its function. All screw holes line up and all is good. I did not wind the spring anymore than just giving it some tension which it already has once you line the moon up to the correct position to gear (spindle). Looking at the teeth on the moon and the gear, it just shows normal wear and there are no major chips (light scratches only) and the same for the moon.
I had to go buy a new retention ring that holds the jump start to the outside ($0.60, no big deal), there is a small amount of play (minimal), but I never paid attention to know if it was there before this. Would having the wrong size retention ring (regarding thickness) cause any problems?
I just need advice if I have overlooked something. Just trying to get my scoot ready for the winter. I know a lot of text with few questions, but I just wanted to be detailed as could be so that you can picture what I am looking at. I could take pictures if needed, but I don't have a way to record sound. Low tech over here.
![Angry >:(](https://www.kymcoforum.com/Smileys/default/angry.gif)
