Did you miss your
activation email
Scooters - 125 to 300
Grandvista 250
Changing rollers, belt and clutch
Topic: Changing rollers, belt and clutch (Read 1960 times)
yahooie
2006 Grand Vista
Newbie
December 06, 2011, 07:08:43 PM »
Does anyone do their own work that can tell me where I can find the tools to change the belt, rollers and clutch springs?
2006 Blue Grand Vista 250
Rudolf
Full Member
Born to be wild!!!
Re: Changing rollers, belt and clutch
July 20, 2012, 09:26:54 PM »
You can make your own tools if you have some steel around, a welder, grinder, drill, etc.
You never know do ya!
Close enough to get the idea!
July 21, 2012, 04:09:36 AM »
A harbor freight 1/2" impact driver/14mm/17mm/37mm sockets. And a mondo size oil filter wrench to hold the clutch. The rest you may have... Search Utube for GY6 clutch/gy6 variator/gy6 whatever for alot of tips. Post up any questions you have,
Rudolf
Full Member
Born to be wild!!!
Reply #3 on:
August 08, 2012, 06:55:09 AM »
I will try to make an universal holder from a piece of 20mm flat bar.
Reply #4 on:
August 09, 2012, 03:14:27 AM »
I just bought a Stage6 clutch bell. I also bought their holding tool. I found I don't need it using an impact. Getting a cheap impact will save alot of useless tools/rig ups. A BETTER tool to get is this
http://www.partsforscooters.com/202-7-Fly-Wheel-Puller
That's worth the money in saved parts/time. You WILL use it too
Rudolf
Full Member
Born to be wild!!!
Reply #5 on:
August 11, 2012, 08:50:58 PM »
I've removed today the CVT and clutch by hand using only a 19mm socket wrench and a piece of pipe for a lever. To hold the clutch bell in place i've made a special holder from a piece of half inch pipe with two pegs welded on it. As for the CVT i've made a universal holder. I've cleaned the parts and put them back...
Back
