Author Topic: 80cc big bore  (Read 2942 times)
sidthesloth
  • Kymco ZX50
Re: 80cc big bore
« Reply #15 on: December 24, 2011, 11:33:15 PM »
Correct, but it should still run.
juice
Re: 80cc big bore
« Reply #16 on: December 25, 2011, 12:06:37 AM »
Does anyone have or know of a successful 80cc 4 stroke conversion ?
Re: 80cc big bore
« Reply #17 on: December 25, 2011, 01:02:42 AM »
Blue, I have two sym vs scooters, a 125 and a 150, the only difference is the cylinder/piston. the only difference in the tramsmissions is the roller weights, 10 v 14 grams and the drive boss is 1mm shorter on the 150.
some scoots are easy to mod and some are not most the 4 strokes I have seen are 50s being made to go faster by bring theam up to a 70 kit or 80 they well coast ya later by doing so.now going from 125 to 150 may be dif.
woodcutter
Re: 80cc big bore
« Reply #18 on: December 25, 2011, 10:33:41 AM »
scuzz, did you installed piston rings corectly?
Hoolander2
Re: 80cc big bore
« Reply #19 on: December 25, 2011, 04:42:11 PM »
So it did start at least once but cut out.  Spark plug is wet.  Try running without the air filter for just a minute.  That might tell you if your jetting needs to go up or down.
