Author Topic: 17mm Pulley Nut  (Read 7427 times)
phin63
Re: 17mm Pulley Nut
« Reply #15 on: March 01, 2009, 12:33:07 PM »
The variator holding tool arrived (Buzzetti #5582) and it worked perfectly,cost about $13(US). I changed the original variator with a Polini Speed Control (P241647),cost about $65(US). The Polini roller weights are 6.9 grams. The Kymco roller weights seem to be just over 6 grams (any marks had worn off/weighed on a digital letter scale). I also installed a Malossi Kevlar X belt (M6113501) which is supposed to grip better and be stronger than the original, cost about $28(US). The Kymco belt (made by Bando) was in excellent shape having under 700 km of use. I took a short test ride and everything seemed to work really well. It looks like the northeast is due for about a week of bad weather, so I'll give it a full test run at the first chance that I get and report the results.        Paul
yajblackburn
  • 2004 ZX50, 2000 People 50, 2002 Yup50
Re: 17mm Pulley Nut
« Reply #16 on: March 13, 2009, 12:09:07 AM »
Thats the cheapest price I've ever seen for a kevlar belt.  I still have the stock belts on the People and ZX with over 10,000 miles on both and still going strong.  Last weekend was in the 50's, took out my People 50 and it actually wasn't that bad.  Keep us posted Phin.
phin63
Re: 17mm Pulley Nut
« Reply #17 on: March 13, 2009, 12:30:51 AM »
I took advantage of the weather to test out the new parts and went for a 26 mile ride, ;D just to be sure. The performace of the scooter was better over all. The Polini variator is supposed to add another 3mph to the top end. I was hoping to get it up to 45 mph but I never did, it seemed to be a little starved for fuel. I'll have to install the larger carb jet and test it out again.  Paul
yajblackburn
Re: 17mm Pulley Nut
« Reply #18 on: March 13, 2009, 02:20:13 AM »
You said you have a different carburetor jet, did you get that at the place in Warwick?  Also, what jet number are you using now, and what are you going to switch to?
phin63
Re: 17mm Pulley Nut
« Reply #19 on: March 13, 2009, 10:27:11 AM »
I am going to install the extra carb jet that came with the scooter. I don't know which size it is, but I think it must have been included with the scooter for derestriction purposes.   Paul
yajblackburn
Re: 17mm Pulley Nut
« Reply #20 on: March 13, 2009, 12:15:39 PM »
The derestrictions baggies that came with the Agility's that I have included the boss drive and main jet.  However, upon furthe inspection I noticed that the jet in the derestriction bag was the same installed on the stock carburetor, #82.  I was told that this is the standard jet.  I was also told to possibly go up to an #85 main jet but haven't looked for it yet.  It might be the same for you.
phin63
Re: 17mm Pulley Nut
« Reply #21 on: March 14, 2009, 11:02:25 AM »
I haven't seen the carb jet that's in the scooter yet. Is such a  small difference in the jet size visable to the naked eye, or is there another way to check? If it is the same then #85 jets cost about $4 on Ebay depending on the seller (without shipping).     Paul
OldGuy
Re: 17mm Pulley Nut
« Reply #22 on: March 14, 2009, 02:10:59 PM »
The only way that I know of to verify the size of a jet is with a set of wire gauges which are extremely costly. Jet size is marked on the head, usually.
Side Note:
Drilling a jet out is not a good idea, in my opinion. It will work but you'll never get a smooth finish and good flow with a drill bit. You could do it with a set of jet reams but, once again rather costly.
OldGuy
Wanna be GrandVista rider
"What the heck happened?"
phin63
Re: 17mm Pulley Nut
« Reply #23 on: March 14, 2009, 11:45:40 PM »
The extra carb jet that came with the scooter is marked N 82.
Re: 17mm Pulley Nut
« Reply #24 on: August 10, 2009, 02:01:51 PM »
I've only been to Java Speed a few times.  They are the only Kymco dealer I am aware of in Rhode Island.  The best place I found for Kymco parts is Burlingtonyamaha.com.  They are right near the American Kymco factory in North Carolina, so they can get those hard to find parts and get them rather quickly.  I live in Newport and am great friends with the local motorcycle shop owner, plus the whole trip over the bridge deal is a pain in the ass, not to mention a $2 toll each way.  It's weird how the impact wrench works.  If you took a normal drill and put the socket on it, it would spin and spin and spin.  But the impact wrench pulses as it turns.  Oldguy knows more about this than I do.  All I know is it definetly works.
..I live in NC...where is there a Kymco factory????
peace
axy
Re: 17mm Pulley Nut
« Reply #25 on: August 10, 2009, 08:05:51 PM »
peace
Just down the road, 2 miles from Qinqi scooter factory... next to Baotian...
Kymco Agility 125 2008
Re: 17mm Pulley Nut
« Reply #26 on: August 11, 2009, 01:42:03 PM »
I use impact also but mostly for takeing the nuts off only its easy to put back on and find a way to hold good enough to put back on with out being to tight.
