Author Topic: 250 to 300 with F.I.  (Read 1804 times)
FireCaptain
« on: January 05, 2012, 02:09:26 AM »
I have a 250 fuel injected. Thing is great except for anything over 65 MPH I am redlining. I am thinking of a 300 kit and new weights. I do not want the overall weight of changing my scoot to a 500 xciting. My question mainly is what kind of fuel injection system is on the scooters. Is it a programed for 250 or can it read and adjusted to a different mixture if I change to 300 c.c. I dont want to go to a heavier scoot for in town but tired of getting almost run over with a 70 MPH speed limit here.
JustWantToRide
Re: 250 to 300 with F.I.
« Reply #1 on: January 11, 2012, 04:48:16 PM »
Upgrading to a different scoot will be cheaper in the long run...
2009 Xciting 500Ri
   52mpg so far
FireCaptain
« Reply #2 on: January 13, 2012, 03:15:31 AM »
Guess variator weights are cheap and easy to try. That will be first. If I have to get rid of the scoot ( I really like this Kymco) Not sure if I want to go to a burgman 400 or to a VStrom bike.....
JustWantToRide
« Reply #3 on: January 14, 2012, 11:36:24 PM »
Odd choice of bikes - but one I keep seeing.  I owned a 2003 Burgman 650, a 2005 Burgman 400 (the wifes), and a 2006 Vstrom 1000.  Now I have a 2009 XCiting 500...  Perhaps you should consider an XCiting 500?
The XCiting 500 will cost you less than the Burgman 400 but have twin front discs instead of a single, have more power - but less storage.  The Burgman 400 sits different than the XCiting's too - your knees will be higher.  The Burgman has a lower seat - and the passenger sits higher - so 2 up riding isn't as stable.  The mpg figures are comparable.
The VStrom's are excellent bikes and will handle tons better than an XCiting could imagine.  The 1000 is a great bike for 2 up or riding long distances at a good pace.  What it doesn't do well (why I traded down) is ride smoothly at slow speeds.  Both VStrom's are tall and a bit on the heavy side - but their height/weight disappear at speed and they are very comfortable.  The 650 could use more power for passing while going uphill and riding tandem (not a big deal) where the 1000 has plenty of grunt for anything.  But the 1000 needs a gear below 1st for offroad, and it isn't smooth at neighborhood speeds.  I loved my 1000, but after becoming a single parent I wanted to be able to carry my daughter on something larger than my Zuma 125 - and the VStrom was just too cumbersome at the speeds I wanted to carry her.
I cruise at 80mph on the XCiting 500 with no problem.  It's only problem is the same as your XCitng 250 - the suspension is meant to be comfortable instead of for handling.  You can only get so good of handling when the engine moves up and down with the rear wheel anyway so oh well...
2009 Xciting 500Ri
   52mpg so far
FireCaptain
« Reply #4 on: January 15, 2012, 02:44:33 AM »
Wow tnx, you answered alot of my questions. I like the burgman because I can reach the ground better than my Kymco and it has awesome storage room. I am thinking the 650 VStrom for a best "all around" bike. I know there capable because a guy I work with just did a southeast texas to alaska and back trip solo. If my 250 would be a little faster on the highway I will probaly keep it. I dont mind spending a grand or so on it for bigger bore, variator if the fuel injection will adapt to the bigger bore. I know Kymco made a 300 xciting, just dont know what approach they did to get it there. If it was an 80's ford fuel injection I would have it down!
