Author Topic: agility 50 HELP  (Read 1417 times)
jasony
agility 50 HELP
« on: January 19, 2012, 11:03:38 PM »
ok guys i have a 09 50  that i bought with some cut wires <was a theft recovery>
i ve downloaded the wiring diagram and re wired what i believe to be is correct
been over it hundred times   i keep burning up cdi boxs... gettin to point where my head hurts and wallet is
starting to hurt id love to get this thing running   i just need spark...
i need some pics of the ignition switch connector to the main harness so i can check mine is corret as they cut the conector out
also i need some one with a test light or meter to check what they have down at there cdi connector
by the looks of the wiring mine is all correct im getting pulse to the cdi and i have power there but i cant get a hot to the coil..
something is burning the cdis up soon as i install them and i cant find it ... any help thanks
any one have a wiring harness key switch and a cdi from a 50 for sale?? last resort
502 690 1117 call or text
Scooter Russ
Re: agility 50 HELP
« Reply #1 on: January 20, 2012, 02:08:09 AM »
I have an 08 agility that I just put a new ignition switch in cuz my scooter had wires cut when I got also! I'll get you a pic & post it here in the morning.
Drive it like you stole it! Lol......
jasony
Re: agility 50 HELP
« Reply #2 on: January 20, 2012, 03:01:09 AM »
ok cool thanks i beleive there right
i think i have a bad original cdi  DC big one
went to a scooter shop and i didnt know there was a AC one
i had them check it on a scoot that had same box SMALL one
it fired theres so i brought home and plugged in mine and it fried it..
so after reading tonight i see kymco,s take DC cdi so im gona try and find one tomorrow
Any one know if the pulser wire sends a ground signal to the cdi ?
as thats what im gettin out of it unplugged and at the box..
i have 1 igniton switched hot black blue
ground GREEN
blue yellow pulsator wire sending a ground circuit
everytime magnet passes while cranking
and have black yellow which isnt getting anything coming out of cdi
therefore beleve the cdi was bad just got f***ed by the shop as they didnt know there are 2 boxes either..
i do know
Scooter Russ
Re: agility 50 HELP
« Reply #3 on: January 20, 2012, 12:37:47 PM »
Ok here's a pic of mine!
Scooter Russ
Re: agility 50 HELP
« Reply #4 on: January 20, 2012, 12:45:39 PM »
Yes most cheaper brands of scoots use an AC cdi & higher end scoots use a DC cdi!
streido
Re: agility 50 HELP
« Reply #5 on: January 20, 2012, 01:25:31 PM »
Try ebay, they had some from china for sale which were pretty cheap a yr or so ago so prob still have them for sale. Just email them 1st to be sure its suitable and is a dc unit.
Chaos is my co-pilot.
jasony
Re: agility 50 HELP
« Reply #6 on: January 21, 2012, 01:33:31 AM »
hey scootrus  what are the colors they connect to i can make some of the blacks out
Scooter Russ
Re: agility 50 HELP
« Reply #7 on: January 21, 2012, 02:45:54 AM »
In the big white connector there are two green wires, one black wire & one red wire. There is a separate rubber coated bullet connector, that has a blue w/yellow stripe!
