Author Topic: People GT 300i Oil Filter ?  (Read 13326 times)
modmaster
  • I will leave no bike I own stock.
Re: People GT 300i Oil Filter ?
« Reply #15 on: July 17, 2012, 02:06:55 AM »
I bought 4 filters from them last week and it worked out well for me also.
modmaster
ailixhomes
« Reply #16 on: July 23, 2012, 06:05:50 AM »
As per my knowledge GT 300i Oil Filter good for engine. I know some advantages of GT 300i Oil Filter like Reusable Technology, Limited Flow Restriction, Extended Life of Conventional Filters, Improved Reliability of Electro- hydraulic Valves, Quick Wear Metal Inspections and many more.
MassScoot
« Reply #17 on: September 11, 2012, 07:21:54 PM »
I did buy five (5) of these from OEMCycle.com and had a great online shopping experience:   Ordered last Wednesday, received them today in the mail (Monday).   Total price was 19.69 (14.70 for the 5 filters + 4.99 S&H).
Thanks guys for the "heads-up" I just noticed that my local Kymco dealer charged me $25.98 for an oil filter (Kymco SKU# 1541A-LEA7-E00) What a rip-off! I went in for my 600 miles service last week.
I just bought 5 each of the HF566's for $19.69 including S/H from OEMCycle.com 5 filters for $6.29 less including freight!
Gloucester, MA. (Home of the Perfect Storm)
2012 Silver Kymco GT300i (Biondi Windshield/Shad SH40 Cargo Topcase)
2015 White Honda PCX150 (Shad SH37 Topcase)
2013 Yellow Lance PCH125 (Shad SH33 Topcase)
Kenneth76
« Reply #18 on: September 13, 2012, 07:16:31 AM »
Thank's  Wiz , I buy 5 oil filter from OEMCycle.com like 10 minute ago , i paid $14.70  plus $4.99 S&H to Florida. ;) .
Kenneth76
« Reply #19 on: September 13, 2012, 07:28:31 AM »
If anyone has a photo of when they changed the oil filter, it would be very helpful will post it here. Actually I would like to see exactly where the oil filter, and as seen when you open to change. ??? Thank you. Kennneth of Cape Coral, FL. 8)
« Last Edit: September 20, 2012, 04:24:35 PM by Kenneth76 »
InAFog
« Reply #20 on: September 13, 2012, 07:46:00 AM »
Wow...so simple. Buy a filter, look under the bike...it will be plenty obvious where it goes...if you need a picture maybe you should let a mechanic do it...
Kenneth76
« Reply #21 on: September 20, 2012, 03:42:50 PM »
I did not think that the oil filter was so small, when I saw the filter was very easy to know where he was installed. I did the oil change, and I did not need a mechanic.
mrmike
  • Syuracuse, NY
« Reply #22 on: January 20, 2013, 05:03:54 PM »
  Thanks for the good info. I just ordered 5 filters from OEM cycle also.
« Last Edit: January 20, 2013, 11:26:13 PM by mrmike »
boo
O ring ?
« Reply #23 on: April 24, 2013, 01:19:14 PM »
Is there an O ring that should be replaced when changing out the filter, or do the new filters come with a new O ring?.
300GTI black
Pro 2A - member GOA & NRA
« Reply #24 on: April 24, 2013, 09:28:59 PM »
  the O ring is on the cap,. inspect it to make sure it is OK. and do not over tighten it when replacing it,  and watch out for the spring in the cap,dont lose it,   and when I clean the wire mesh filter I use a needle nose plyers to get it out, gently,. air blow it clean, drain bolt beside it  drain and tilt scoot over a little to get last of oil out,. put it together add oil your done,,,..
boo
« Reply #25 on: April 25, 2013, 01:48:19 AM »
In other words, people are re using the O ring. May not be a good idea.
Maybe someone will come up with the exact replacement size that we can buy at Lowes or Ace Hardware.
300GTI black
« Reply #26 on: April 25, 2013, 02:59:33 AM »
  Ive done 10 oil changes ,and the O ring is still good,. I will try to match it up next oil change, and see if the hardware store has that size,.
boo
« Reply #27 on: April 25, 2013, 12:50:41 PM »
Thanks de dee. That will help everyone.
Over time heat will cause O rings and rubber gaskets to become brittle and are more likely to leak.
« Last Edit: April 25, 2013, 12:59:18 PM by boo »
300GTI black
« Reply #28 on: April 26, 2013, 02:19:01 AM »
Our motor oils contain an additive that rejuvenates hardened oil seals and also prevents rubber oil seals to harden... before putting on the cap, wipe a small amount of motor oil on the o-ring, this will really help lengthen the life of the o-ring...
boo
« Reply #29 on: April 26, 2013, 03:03:08 PM »
That is good to know Vivo. Thanks for the heads up.
I have been putting a dab of silicon grease on all my O ring before using.
Did not know modern motor oils had an additive to protect rubber.
300GTI black
