Author Topic: Tires  (Read 19371 times)
dudley
Tires
« on: January 31, 2012, 05:56:04 PM »
Who makes a 100/80-14 front tire for the super 8?
Lots of options for the 120/80-14 rear.
Can I go 120 on the front without compromising handling?
What do you have on your super 8?
2010 super 8 150  red/black
bought march 2011
4000 miles march 2012
dr pulley variator w/stock weights
top speed 61.5mph  gps verified
Re: Tires
« Reply #1 on: January 31, 2012, 10:51:51 PM »
Hey Dudley. There are alot of options volunteered on the forum. I believe they are in the People section. You can upsize, and alot of the time you are MUCH better off. I would recommend keeping a larger tire on the rear however. Now that I'm thinking about it I believe Heidenau (bad spelling) has tires in your size
Re: Tires
« Reply #2 on: February 01, 2012, 03:14:11 PM »
Mine came with a 120 on the front as standard equipment.
dudley
Re: Tires
« Reply #3 on: February 01, 2012, 09:35:31 PM »
Actually not alot of options in the rear size either.
Seems to be more popular for a front tire.
Should I go  120 front(will it fit)
And 130 rear?
Or two 120s.
Don't know dammit about scooter tires.
bought march 2011
Re: Tires
« Reply #4 on: February 02, 2012, 12:42:22 AM »
It's more about how you like to ride. The steering angle will change w/ tire diameter, and placement so I think of it as how you would like the bike to feel. Bigger tires are generally a softer feeling ride, and vice versa. Then theres style... If you allways feel like you are falling over the bars go w/ (2) bigger tires the same size. If you want a quicker feeling in the front go smaller on the front, and bigger on the rear.
dudley
Re: Tires
« Reply #5 on: February 02, 2012, 01:14:59 AM »
Thank you, zombie.
That is some info I can apply while researching further.
Teaching me to fish, so to speak.
bought march 2011
Re: Tires
« Reply #6 on: February 02, 2012, 01:44:41 AM »
The super 8 has a tire fender/hugger with only a small space between that and the tire. A big tire will not fit unless you remove the hugger.
Re: Tires
« Reply #7 on: February 03, 2012, 12:12:26 AM »
Or modify it. YEEEEEHAWWWWW!
dudley
Re: Tires
« Reply #8 on: February 03, 2012, 11:29:02 AM »
Klaviator,
What's on the rear?
bought march 2011
Re: Tires
« Reply #9 on: February 03, 2012, 09:46:41 PM »
Klaviator,
What's on the rear?
I have a 120 front and rear.  Both Chen shins.  At 4900 miles they show little signs of wear.  I'm guessing the rear will last 10,000+ miles and the front much longer than that.
Re: Tires
« Reply #10 on: February 04, 2012, 12:17:23 AM »
Chen Shin s last forever cause they are hard as plastic. Great for touring. Suckified in the rain or morning dew.
Re: Tires
« Reply #11 on: February 04, 2012, 02:59:56 PM »
Actually I was thinking hard as concrete ;D  Despite this, on dry roads they have plenty of traction.  The S-8 runs out of ground clearance before the tires run out of grip.  I take it easy when the roads are wet and haven't had any problems so far.
Re: Tires
« Reply #12 on: September 12, 2012, 04:32:14 PM »
At nearly 8000 miles, my rear tire is wearing out.  I haven't been able to find a single 120/80-14 rear tire although there are front tires in that size.  Has anyone out there replaced their rear tire?
jmccoach
Re: Tires
« Reply #13 on: September 14, 2012, 08:09:39 PM »
I'm at 11,000 miles on the originals and they still look good.
Re: Tires
« Reply #14 on: September 15, 2012, 02:23:50 AM »
I have 10,000+ on the originals and still looks like new...  ::)
